First Time Planer Blade And Lathe Tool Sharpening
aloibl wrote:Charlese is correct. I used 150 grit sandpaper with a conical disc. Again the biggest problem I had was keeping the nylon inserts in the jig. The other problem I had was setting the conical disc up to where it was grinding the edge of the blade without taking to much off at one time. I kind of "snuck" up on the blade by moving the disc a little closer by extending the quill.
There is 'another' way?:D
fjimp
Post by fjimp »
JPG40504 wrote:There is 'another' way?:D
Do tell? Will Dusty agree? Jim
F. Jim Parks
Lakewood, Colorado:)
fjimp wrote:Do tell? Will Dusty agree? Jim
I do not know of a 'better' way than sneaking up on the grind depth..
