What Makes It Noisey
For noise defferences, I suspect drive belt condition, the amount of control sheave slider wear on the shaft and key/keyway, and of course other wear (duh!):rolleyes:
I know when I temporarily used a Gates drive belt, the machine was a lot noisier.
A v-belt running on vaned pulley sheaves that themselves slide on the shafts cannot possibly run 'quietly' unless no slop and very smooth surfaces..
Add a splined quill shaft driven by a poly-v belt driven by that vaned sheave(idler) and more noise.
I agree that drive belt condition and sheave surfaces are relevant to amount of noise.
What surprises me is a worn gilmer drive(sample of one) seems to be quieter.
But then I did 'dress' the sheave surfaces with a file.
billmayo
Post by billmayo »
I believe most of the headstock noise is from the V-belt operating over the sheaves. I found the DC motor conversion I did was very quiet.
I have been refacing the sheaves to remove any scratches, nicks and worn areas, not to reduce any noise or vibration. The worn areas can be deep with grooves. I have to reject about 10% of the sheaves. Never really thought about noise or vibration as a reason to reface the sheaves as I have done this for years. It also makes the sheave vanes look good. Some headstocks can be quite loud at times. I find I have to try different motor belts some times to reduce vibration and noise at certain speeds. V-belts can have more effect on vibration and noise than most people would believe. The Gilmer or Poly-V belt tension also effects the noise and vibration levels. I find playing with these 2 areas helps me to reduce noticeable noise and vibration.
WmZiggy
Post by WmZiggy »
I thought of that after I wrote it. Vibration is tricky business to address, just ask the people who build airplanes.
WmZiggy
williamz@aol.com
transplanted
Post by transplanted »
One thing I noticed on my 510 that drove me crazy until I found it, was the knurled thumb screws that secure table / extension tubes to the saw. A few weren't tight and they rattled. Tightened them up and buzz/rattle stopped.
My wife says that I've never met a tool I haven't liked. People on the other hand......
transplanted wrote:One thing I noticed on my 510 that drove me crazy until I found it, was the knurled thumb screws that secure table / extension tubes to the saw. A few weren't tight and they rattled. Tightened them up and buzz/rattle stopped.
To that list add the knob (lower saw guard) that secures the riving knife (upper saw guard) .
WmZiggy
Post by WmZiggy »
I suppose if we worked all the rattles out in the midst of new found quiet we would long for the good ol' days when SS rattled like a Model 'T'.:D
WmZiggy
williamz@aol.com
nil
Post by nil »
When I got my new mark 7 I found it was noisier than expected.
It turned out the jointer connection was rubbing up against the side so I just needed to move it away from the sides.
You can imagine my first reaction when a new machine made so much noise.
Culprit
Post by Culprit »
My A headstock Gilmer machine runs quieter and smoother with a PowerTwist Link Belt than it does with a V belt.
1955 Greenie, modified to be reversible
swampgator
Post by swampgator »
Culprit wrote:My A headstock Gilmer machine runs quieter and smoother with a PowerTwist Link Belt than it does with a V belt.
I would love a pic of that. Can you show?:)
Steve, the old Florida gator
I just love it when she says I can go make sawdust. ;) :D
