That's what I see (a 510 main table and rip fence) but not sure it has table posts/trunnions.dusty wrote:Maybe it is a main table and not an extension table but in both the 1st and 3rd images there is a table with a rip fence attached. They look like 510 items to me.
Advice/identification needed
I don't see the jointer or the jig saw in the photos.joshh wrote:If there is a WORKING jointer, jig saw, and bandsaw it's definitely worth $200 in my opinion BUT as others have stated there are some concerns. One of my concerns is the posts sticking out of the headrest. Are these to the bandsaw? Do they come out or are they "stuck".
I have doubts the SPT's are working well.
Also, what part of the world are you in?
With the sparse info seen, I would start at $50. The paint appears oxidized, the jointer and jig saw are not apparent and the 510 table/fence greatly confuses the issue. Depending on what is in(or not in) the crate could alter that 'offer'. If it runs 'correctly' and the SPTs do also it is worth more.
Looks like a 'project' to me! Maybe the toilet will make it look better!:D
It also looks like a SS Inc. offspring.
Closer examination reveals:
The belt cover on the ground???
The 510 table has no trunion.
It has a 500 lower saw guard mounted.
It has a 510 lower saw guard in the crate.
The casters have the crank close to the end.(probably 1970's vintage).
The paint appears 'smooth'.(1970's again).
It likely started life as Mark 5 from SS Inc.
At least it has a drill chuck key!
Apparently it doesn't run correctly. Reading over on the Lumbejock's site where he's got 2 theads up about this listing the owner is telling him it trips the breaker.JPG40504 wrote:With the sparse info seen, I would start at $50. The paint appears oxidized, the jointer and jig saw are not apparent and the 510 table/fence greatly confuses the issue. Depending on what is in(or not in) the crate could alter that 'offer'. If it runs 'correctly' and the SPTs do also it is worth more.
The milk crate points to
Portland OR.
Portland OR.
Wow, the guys at the LJ forum were Right! You guys are amazing!
So much knowledge.
And great detective work on location. I live in Portland Oregon and the SS is closer to Corvallis.
By chance are any of you in the area?
The seller says that he has a 15amp breaker and it tripped it after running for a few minutes.
Is that a reason for concern? I assumed that he just needed a larger breaker...
Also sounds like there are quite a few pieces here and I will have to ask for more pictures. The jointer/jig saw are not pictured.
So much knowledge.
You are correct, but I figured that out by going to Lumberjocks and looking to see where the member was from. You got that off the milk crate? Unbelievable!JPG40504 wrote:The milk crate points to
Portland OR.
Well, we should have scared the original poster off by now!
