10ER or 1954 mark v for lathe?
skou wrote:Cougar, I was going to say, get the Mk5 for a stand-alone drill-press, but the ER makes a better drill-press.
The Mk5 is a MUCH better table saw, though!
Chances are, your 54 Mk5 was built using ERs as tools.
steve
And any 2013 Mark 7!;)
skou
Post by skou »
Thank you, kind sir!
Yes, there are still ER based custom-built tools on the
production line.
And, I still have some antique Griswold skillets, that still
work as designed.
Oh, the sign-in for the yahoo ER gmail files site, Cast Iron.
wonder why?
steve
apexsunguitars
Post by apexsunguitars »
Will the SS Universal Lathe Tool Rest fit on the 10ER tools? I am admittedly ignorant of the similarities of design between the 10ER and Mark Vs.
Two each Shopsmith Model 500, 505, 510s. Sawsmith Model 500003. Most of the SPT goodies aside from the compressor and the Planer.
cougarboy
well...
Post by cougarboy »
Thanks for all your input. I went to check out the Mark 5 and the motor wasn't wanting to spin so they said I could have it for $25 if I wanted to play with it! I will probably set up the 10ER as the lathe though as that seems to be the general consensus.
skou
Post by skou »
apexsunguitars wrote:Will the SS Universal Lathe Tool Rest fit on the 10ER tools? I am admittedly ignorant of the similarities of design between the 10ER and Mark Vs.
From what I've heard, Yes!
steve
skou
Post by skou »
cougarboy wrote:Thanks for all your input. I went to check out the Mark 5 and the motor wasn't wanting to spin so they said I could have it for $25 if I wanted to play with it! I will probably set up the 10ER as the lathe though as that seems to be the general consensus.
Cougar, $25 for all those parts? Probably take me 1/4 second to decide!
You CANNOT have just one Shopsmith. (I think Lay's potato chips copied that!)
steve
skou wrote:Cougar, $25 for all those parts? Probably take me 1/4 second to decide!
steve
I agree! $25? A no brainer for sure. Go back an see if they will take $20!:D
skou wrote:From what I've heard, Yes!
steve
The clamps will not fit the way tubes, but they be a simple thing to make.
Sorry! Wrong thingie. I was thinking lathe duplicator. Please ignore!
greitz
Post by greitz »
The UTR sits on top of the carriage, not the way tubes. Is the 10ER carriage roughly the same size as the Mark V carriage? If so, it should work fine.
Gary
fredsheldon
Post by fredsheldon »
Since I have the UTR and both a 520 and 10ER, I will resolve this issue tonight.
Fred Sheldon
The Woodlands, Tx
