Ok that does it. I need to come over and see how that's done!!2centsworth wrote:Here is the picture of the board when cut.
[ATTACH]23566[/ATTACH]
It is amassing to see how it transforms.
Fred
Good catch......now I can think of at least three ways available to me to mount it without a through hole.reible wrote:Well you have gone about as far as I have using the ringmaster. I did a couple of trial containers just to see how it worked. I did use if on another project but those rings didn't have to fit with anything else.
I do wonder how you mounted your base as I can not see a hole in it????
So now you have an expert to give you advice how about getting him to share with us too? Pictures, text, movies, they all work.
I'm interested in any projects you might come up with. I just haven't seemed to have taken the time to figure much of it out yet.
Thanks,
That is two more than I. What are they?SDSSmith wrote:Good catch......now I can think of at least three ways available to me to mount it without a through hole.Nice job, Jerry and thanks for the inspiration!
I feel your pain and frustration - they make it look simple and if you are an engineer with a masters degree in trigonometry you could sit and calculate the settings. I watched all the videos and shopsmith segments and the excel spreadsheet was when I was ready to sell the darn thing having not even turned it on. I said there has to be a better way. So :reible wrote:Well you have gone about as far as I have using the ringmaster. I did a couple of trial containers just to see how it worked. I did use if on another project but those rings didn't have to fit with anything else.
Thanks,
Absolutely correct and then some. Will be exciting to see what can be made. Upside down / alternated / canister style etc....benush26 wrote:Now that is truly cool!![]()
Very well done!
Question....
Would it be possible to create a vase with multiple curves like S shapes by making a couple of bowls, flip one, leave out that base, then glue top to top?
Ain't it just cool what can be made with wood?!![]()
Be well,
Ben
That is the million dollar question and what you strive for. If all lines up it fits like a glove.idcook wrote:I’m assuming that the circumference of the bottom of each ring is equivalent to the top of the next smaller ring.
Zat right?
