That is elegant! Pretty cool posts gentlemen ......
Determine the Angle with No Angle Gauges
- rjent
Wow
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
1951 jigsaw X 2
Right angle sides with 12 inch hypotenuse by 64ths
As promised..........
[ATTACH]25169[/ATTACH][ATTACH]25192[/ATTACH]
Some errors! I will replace this. DONE!!!.....................................Done again;)
- angles2.jpg (159.78 KiB) Viewed 3045 times
- angles3.jpg (159.9 KiB) Viewed 2990 times
- rjent
JPG40504 wrote:As promised..........
Thanks JPG, you are the man! Nice reference material!
Dick
1951 jigsaw X 2
1951 jigsaw X 2
Set the Angle with No Angle Gauges
My last post on this subject matter.
Rather than use the rip fence, I suggest that it would be better to use the miter track as the reference guide. I have a bar cut to fit snugly in the miter track just for this purpose. Using the fence introduces still another variable.
The reference chart has grown to include a number of angles (example: 25.71429 degrees) that I am not likely to use but the reality is that there are no limits. Furthermore, this can be done without the luxury of a digital angle gauge. This is good since my digital angle gauge shows only two points to the right of the decimal.
[ATTACH]25189[/ATTACH]
Using the ruler to position the small square at 10" facilitates the use of a sine table to determine the length of the vertical element. Reference the sine table for the degree in question and move the decimal point of the sine value (.4338) one place to the right. This is the approximate length of the vertical element expressed in inches (4.34").
NOTE: This works only at 10".
[ATTACH]25191[/ATTACH]
- Two Squares and a Ruler at 25.71429 degrees (Custom).png (21.5 KiB) Viewed 3000 times
- Two Squares and a Ruler at 25.714 (Custom) (2).png (25.7 KiB) Viewed 2997 times
Actually that is 25.71428571°:D
I know that is ridiculous accuracy, but is what was used.
Reality returns with the rounded 64ths.
I included the 'extra' angles for segment turners.
I added a second chart for those with a 10" ruler above(post 12).
Y'all do know you can copy/save those jpg files from the screen by right clicking on them.
- rjent
You guys take my breath away .....
..... or maybe it's just my age ....
Dick
1951 jigsaw X 2
1951 jigsaw X 2
rjent wrote:You guys take my breath away .....![]()
Nah! Must be that super heated super dry air you are breathing!;)
P.S. You ain't old(yet)!
- rjent
[quote="JPG40504"]Nah! Must be that super heated super dry air you are breathing!]
Super heated dry, high altitude air to be correct. Hummmmm, not old .... OK, I agree with ya!
Dick
1951 jigsaw X 2
1951 jigsaw X 2
