Drilling into dowels - Jig ideas?
masonsailor2
Re: Drilling into dowels - Jig ideas?
Post by masonsailor2 »
It might be easier to make a jig for each size dowel by drilling a hole through a piece of 2X4 or something similar. That will hold the dowel secure and also support the dowel to prevent any chipping or a blowout.
Paul
everettdavis
Post by everettdavis »
I don't know if a 4" would accommodate all your needs, but the small Bessey I cite below (from Home Depot) with the non marring jaw accessory might be a solution.
Couple these with some T-Slot adapters to lock it down, and it might be a solution for this and any number of small drilling needs.
Obviously Bessey sells a range of vice sizes, as do others.
Under $25 it might be a consideration.
Bessey Vice at Home Depot.jpg (20.29 KiB) Viewed 10597 times
Or you could fabricate your own v-block jaws if you own the Shopsmith Combo vice already.
Shopsmith combo_vise.jpg (51.89 KiB) Viewed 10596 times
everettdavis
Also check out Shopsmith Auxiliary Vise Jaws for more ideas…
http://www.shopsmith.com/ownersite/cata ... e_jaws.htm
You can buy the kit and plans obviously, but you can fabricate them on your own…
Everett
gatheringsplinters
Post by gatheringsplinters »
Ooooohhh,
I may have to check out that vice!
Mark V 500 (1984) - Shopsmith Bandsaw (Older Model with Cast Iron Table) - Shopsmith Jointer
Woodworker Level: Beginner
Boulder Colorado
Instagram: gathering_splinters
Youtube: gathering splinters
ERLover
Post by ERLover »
everettdavis,
Thanks for spending some of my money!!!! :rolleyes:
After seeing the pic of the SS vice you posted here, I ordered one tonight, I dont need one often, but when you do, you do. I wish it had a flat side to set something in it vertically, but then I thought, no I have a SS, just do it in horizontal boring mode.
everettdavis
I have both one of the new ones, and one from 1980 (like the one pictured below) when I bought my first new Mark V at the Shopsmith store on North Central Expressway in North Dallas.
I use them both all the time. I will look up the OEM name for the Manufacturer when I have time and post it, as the OEM guarantees them for life.
Everett
Combo-vise 1980.jpg (54.83 KiB) Viewed 10549 times
everettdavis
The OEM for Shopsmith on that is BORA. The vice is a 551027 from AffinityTool.com
They also offer a Bora 90 Degree Corner Clamp (Bora 551025) Quick Release Corner Vise for $30 that I have my eye on.
Everett
Bora 551025 Corner clamp.jpg (21.53 KiB) Viewed 10546 times
Since we are talking vices/vises here is a post about them:
http://www.shopsmith.com/ss_forum/woodw ... 15756.html
everettdavis
On the subject of vices, I have been quietly looking for a cross slide vice that would easily attach but haven't found one yet.
I want not to build a sliding base, so I can easily move it between Shopsmith and regular upright drill press. I've seen Grizzly and HF but wasn't exactly what I wanted. Milling bases I have seen so far are too heavy.
Anyone have a recommendation for a good one under $120? I've been watching eBay but due to the weight, the shipping is high. If I can find the right product, finding a supplier I can bundle something else with to get free shipping should be possible.
Everett
Considering Wilton 11694 Cross Slide Drill Press Vise on sale for $134.99 at CPO
wilton 11694.jpg (21.06 KiB) Viewed 10527 times
everettdavis
Just found it at JB Tools for $121.25 with free shipping...
Anyone have one?
