Is "Powertool Woodworking For Everyone" also for Mark 7?
the1avi
Re: Is "Powertool Woodworking For Everyone" also for Mark 7?
Post by the1avi »
reible wrote: I also was just looking at my book and noticed that there was another section called "Under Table Routing and Shaping with the Double-Tilt System" that I seem to recall being missing in the other manual. You might want to see if you have a similar section or have it under another name...... Pages are labeled B-1 thru B-22.
I have the following sections:
  • A[1-12]: Safety and Electrical requirements
  • B[1-16]: Terms, parts lists, and exploded views
  • C[1-32]: Unpacking, alignment, mode setups
  • D[-47]: Powerpro headstock operations, table sawing, disc sanding, vertical drilling, horizontal boring, lathe turning, under-table shaping, pin shaping and routing, over-table routing
  • E[1-33]: Maintenance and troubleshooting
As far as I can tell, there is nothing about shaping with the double-tilt system.
the1avi
Post by the1avi »
What I meant is that it doesn't mention the double-tilt system.
Maybe they thought it is a given since you can't do under table shaping without the double tilt system. The MK 7 is double tilt by default.
Default makes sense.
I bought the Mark 7 manual recently after upgrading my Mark V 520 to a Mark 7. This is the manual I received.
Notebook cover
Notebook cover
Inside first page
Inside first page
the1avi
Post by the1avi »
My cover is different but the book itself seems the same based on your first page.
Manual For The Shopsmith Mark 7 smaller.jpg (246.42 KiB) Viewed 14149 times
