New Shopsmith Setup
davebodner
Re: New Shopsmith Setup
I'm guessing you could've simply let the excess mineral spirits evaporate. Of course that would've left you with less actual wax than you'd paid for.
If you are in a hot climate like me try to keep the wax in a cool area. An air conditioned house is ok. I had some go liquid a few years ago but I salvaged it by stirring it up an storing it in the house.
Got my mk 7 but there was damage to the main table and the rear rail assembly was snapped off and laying in the bottom of the box. It broke where the 3 bolts mounted it to the table. There are half moon piece broken off the table. I called Customer service and they are looking into it which is supposed to take 24-48 hour and then they can send a replacement. Which kind of sucks but its the shippers fault. Looks like something was pressed up against the side and or maybe they tied it off there. There is an indentation inside the box where the box was pressed into the rail.
Everything else sees to be there but I cant figure out what these 2 little l shaped aluminum brackets are for. The chuck was the keyless one which I wasnt expecting.
- IMG_3970.jpg (94.3 KiB) Viewed 16627 times
The shipper (Shopsmith) or the carrier (someone else)?Bart430 wrote:Got my mk 7 but there was damage to the main table and the rear rail assembly was snapped off and laying in the bottom of the box. It broke where the 3 bolts mounted it to the table. There are half moon piece broken off the table. I called Customer service and they are looking into it which is supposed to take 24-48 hour and then they can send a replacement. Which kind of sucks but its the shippers fault. Looks like something was pressed up against the side and or maybe they tied it off there. There is an indentation inside the box where the box was pressed into the rail.
I've never purchased a Mark 7 so I don't know what the shipping container is like but if it is designed for the weight, size and shape of the item being packed the cargo (Mark 7) should be fine.
I hope you took pictures of the carton before you unpacked - just in case. Carriers work real hard at not accepting responsibility if they can lay it off on "inadequate packing".
dusty wrote:The shipper (Shopsmith) or the carrier (someone else)?Bart430 wrote:Got my mk 7 but there was damage to the main table and the rear rail assembly was snapped off and laying in the bottom of the box. It broke where the 3 bolts mounted it to the table. There are half moon piece broken off the table. I called Customer service and they are looking into it which is supposed to take 24-48 hour and then they can send a replacement. Which kind of sucks but its the shippers fault. Looks like something was pressed up against the side and or maybe they tied it off there. There is an indentation inside the box where the box was pressed into the rail.
I hope you took pictures of the carton before you unpacked - just in case. Carriers work real hard at not accepting responsibility if they can lay it off on "inadequate packing". The two aluminum pieces appear to be the alignment tool for attaching the tasble rails to the table at the correct height; although, mine are both the same length. Yours appear in the photo to be different sizes.
Their use should be well documented in the assembly instructions which I am sure you have read a couple times.![]()
I would sure like to see a photo showing the broken areas on the table.
Those "brackets" are the jigs to align the rails to the table.Bart430 wrote:Got my mk 7 but there was damage to the main table and the rear rail assembly was snapped off and laying in the bottom of the box. It broke where the 3 bolts mounted it to the table. There are half moon piece broken off the table. I called Customer service and they are looking into it which is supposed to take 24-48 hour and then they can send a replacement. Which kind of sucks but its the shippers fault. Looks like something was pressed up against the side and or maybe they tied it off there. There is an indentation inside the box where the box was pressed into the rail.
Sorry carrier is the one I believe responsible. It looked like it was packed fine, just some strong outside pressure was put right where the rail attaches to the table. At least that is what it looks like to me.
Thanks John, I will have to look in the books to see where and how to use them now.
Dusty I took pics and sent them to Shopsmith while it was still in the box. You can see the indentations on the inside of the box.
