Ed in Tampa wrote:...
I think the biggest concern is the Radial Arm if you use a positive hook angle blade the blade tends to climb. If you ever had a Radial arm saw climb on you it is scarey. The blade sort of jumps atop the wood instead of cutting through it come rushing towards you. ...
Haven't had a problem with climb since I went to a negative hook angle blade. While RAS climbing is scarey it is far less scarey and dangerous than a table saw kickback.
Yep! that'll work! However the climbing issue is why - [when I had a RAS as my only power saw (about 30 years)] - I made it a practice to push the saw through the wood rather than pull the saw toward me. Fence adjustments? All the time!
Never did get smart enough to look for of get a negative hook blade:o .
