Need Help With Material Selection
Ed in Tampa
Post by Ed in Tampa »
You didn't say what it is sitting on, wood or concrete.
MDF would be my choice. First MDF doesn't soak up moisture any more than other wood and in some cases less especially if it is painted or coated in some way. Second for price you will be getting the biggest bang for a buck if you use MDF. After all is is just a cubby hole storage unit.
Now when I say MDF I mean MDF not particle board.
If you were setting this on concrete you need to use treated wood.
Rule of thumb any wood that comes into contact with concrete must ALWAYS be treated wood.
To satisfy the above and still use MDF or PLY you will need to use treated wood furring strips to build this on. Or you could also make the bottom board all presure treated ply.
After that build up using MDF and give it a good coat of paint, clear finisher (Varnish, lacquer, shellac, Poly) or a good good coating of oil
(tung or boiled linseed) and everything should be find.
If I was building it from either ply or MDF I would be tempted to make the outside verticals from 5/8 or 3/4 the rest since you don't have any shelf span wide enough to cause sag I would do in 1/2 to give you more room and an attractive proportional appearance. Building it all from 5/8 or 3/4 works but you are using a lot of room up plus it is liable to look overbuilt (read as saying clunky)
Ed in Tampa
Stay out of trouble!
mountainbreeze
Phase I Complete
Post by mountainbreeze »
After 4 sheets of plywood, 360 dadoes and 129 rabbets, I finally finished Phase I (carcus and first round of bins). I took the advice of some of the replies (thanks to all who replied) and this is what I came up with.
Two more sheets of plywood, 208 dadoes, and 112 rabbets to go!
[ATTACH]13245[/ATTACH]
It looks as though phase I has concluded on an up note. At least Meow seems to approve.
Underdog
Post by Underdog »
Looks great! I really like the colors you chose!
Really good work!!!!! One can see the straight lines and level shelves and know this is fine workmanship. You did your planning and milling with a lot of forethought. Also the drawer/box fronts show your planning and patience.
Congratulations! Mountain......
holsgo
Post by holsgo »
Impressive.
wannabewoodworker
Post by wannabewoodworker »
Sweet I may have to make me up some of those cubbies. Very nice work indeed!
Michael Mayo
Senior IT Support Engineer
Soft Designs Inc.
albiemanmike@gmail.com
1960's SS Mark VII, 1954 Greenie, 1983 Mark V, Jointer, Bandsaw, Jigsaw, Dewalt Slider, Delta Super 10, Delta 8" Grinder, Craftsman compressor, Drill Doctor, Kreg PH Jig, Bosch Jigsaw, Craftsman Router and Table...........and adding more all the time....:D
mountainbreeze
Underdog wrote:Looks great! I really like the colors you chose!
Yeah, me too. I was trying to decide what colors to use so I looked around my garage and saw my old Craftsman toolbox - gray with red drawers - decision made!
jimsjinx
Exellent job!!
Post by jimsjinx »
Only because I am jealous, I must hate you now! Just kidding! I have wanted to do a similar project, but just haven't taken the time and $$ to do it. VERY nice job!! jimsjinx
If you are a part time band leader, does that make you a semi-conductor? Where do all the "unguided" bombs go?
swampgator
Post by swampgator »
Very nice plan, execution and colors. Great job! :)
Steve, the old Florida gator
I just love it when she says I can go make sawdust. ;) :D
