mountainbreeze wrote:I find myself wondering if, when the tall fence is installed and it is not at 90° to the table, how would you adjust it?
If you make it with flat workpiece, it shall be correct. If not, 'adjust the fence'.
i.e. Why worry? I suppose one could shim it between the fence.
SDSSmith wrote:and use it as a jointer fence extension like the one shown here from PTWFE.
SORRY but those measurements are off. Won't work for the jointer.
SS 500(09/1980), DC3300, jointer, bandsaw, belt sander, Strip Sander, drum sanders,molder, dado, biscuit joiner, universal lathe tool rest, Oneway talon chuck, router bits & chucks and a De Walt 735 planer,a #5,#6, block planes. ALL in a 100 square foot shop. .
beeg wrote:SORRY but those measurements are off. Won't work for the jointer.
Yep the 1989 version blew it! Same as online version.
7" too long'(6" better)
1 13/16(+3/8") too big(1 1/16 correct) <<<<<<the only real error<<<<< not clearly drawn. holes 1 7/16 above infeed table top surface.
9 7/8" correct(wrong(10") in 84 version)
The rest seems ok.
Earlier version(Greenie vintage) left off dimensions entirely[guess we were smarter back then:D].
Interesting last couple of posts. If nothing else it proves you need to check the plans against the real hardware before you start layout and the build.
I do not have the jointer but i do have the shopsmith auxiliary fence (555653). Paper work reflects 5/99, so it has to be since then that I got it.
I did a quick review of how it is built and then took some ruff measurements. First an over view of the part.
[ATTACH]14257[/ATTACH]
Using the right side as a reference the first hole is 7" in, the second is 17" and the last hole is 18-3/4. The first and last hole appear about 1-5/8 up from the bottom reference. The other hole is about 2-1/8" up. (holes are referenced from the lowest reference in virtual space for two of them).
The following note gives this information:
[ATTACH]14258[/ATTACH]
From this we can gather that there are more then one fence out there. That makes drawings questionable unless they say for which version they cover.
JPG40504 wrote:Yep the 1989 version blew it! holes 1 7/16 above infeed table top surface.
My unknown version says to use 1" flat head screws, so no measurement needed. BUT on my fence, the holes are KNOT on an even plane. So 1 7/16 above the infeed table wood knot work to well.
So I measured the holes and came up with 1.5" above the infeed and 1 15/16 above the cutter.
reible wrote:Interesting last couple of posts. If nothing else it proves you need to check the plans against the real hardware before you start layout and the build.
Well that explains part of the confusion!
Live and learn! Whoda thunk more than one version of the fence!:eek:
