What Kind of Wood is This?
bffulgham
Web sources I use to help me ID wood
Post by bffulgham »
This linkfrom Wood Magazine is pretty good.
I like thisone even more from WoodWorkers Source as it splits into domestic and exotic categories.
Bud F.
Looks more like a deer horn than wood.
myoung44708
Post by myoung44708 »
[ATTACH]14671[/ATTACH]
Just trying to get a picture in the posting. I will now try to get a picture that is not too big!
Block O.jpg (43.63 KiB) Viewed 2326 times
Martin
1983 MARK V - 500
1960...ish MARK VII with a 510...ish table
myoung44708
So...I take a picture with the Nikon and it is too big...way to big! All of the other cameras in the house, same thing, I resized it and this is what I got[ATTACH]14672[/ATTACH]
I hope this is good enough to see the grain and color.
Martin
1983 MARK V - 500
timsturnings
Post by timsturnings »
Looks a lot like Walnut to me.
Seven days without turning makes one weak. :o
1952 Shopsmith 10er(restored)with Speedchanger,1952 Craftsman 10" table saw,Jet 1014 lathe(VS),HF VS 95607 Lathe,Craftsman Drill Press,55 Gal. Tornado Dust Collection System,Shop Wide Overhead Vac piping,WC slow-speed grinder,Wolverine sharp. system,Grizzly GO580 14" Bandsaw,Rikon Disk/Belt sander,HF Pressure Pot, JB 7 CFM Vac pump,TurnTex Stabilizing Chamber. (My 16' X 20' shop is full to the gills)
robinson46176
Post by robinson46176 »
It does look a lot like walnut. Then again it also looks like some aged sycamore does after age darkening. Sycamore was a very commonly used beam / framing wood here next door in Central Indiana. It still is used a lot for larger wooden beams. While usually a utility wood it can have very pretty graining and in some cases after staining it resembles wild cherry a lot. Not the most stable wood on the planet and must be well protected from any weather.
RobertTaylor
Post by RobertTaylor »
walnut should be easy to identify by it's smell, very distinct
pennview
Post by pennview »
If the wood shows some pith, it's very easy to identify walnut as the pith is segmented or partitioned. It's the only wood with pith that looks like this --
[ATTACH]14674[/ATTACH]
Art in Western Pennsylvania
