First shop smith
mustangpalmer1911 wrote:I have been watching even more vids about the SS since I picked it up WOW is there anything it wont do?
There are somethings it will not do, but I cannot recall them at the moment! :D Seriously there are. You will discover them as time passes. You shall also discover workarounds!
What in tarnation is a 1911?:confused:
jm51
Post by jm51 »
Still can't get my Shopsmith to run Gcode although I have seen one conversion. :cool:
1911 = handgun?
mustangpalmer1911
Post by mustangpalmer1911 »
1911 pistol. The grips are done and the finish is drying I will post the pics soon.
JPG40504 wrote:There are somethings it will not do, but I cannot recall them at the moment! :D Seriously there are. You will discover them as time passes. You shall also discover workarounds!
Google man Google 1911 grips
from wikipedia:
The M1911 is a single-action, semi-automatic, magazine-fed, and recoil-operated handgun chambered for the .45 ACP cartridge.[1] John M. Browning designed the firearm which was the standard-issue side arm for the United States armed forces from 1911 to 1985.
wiredone
Post by wiredone »
It seems like the coffee maker function on mine isn't functioning correctly...must be some gummy wood residue in the temperature gears.:D
www.wirewerkes.com
Hiding in a Joshua Tree.
fjimp
Post by fjimp »
wiredone wrote:It seems like the coffee maker function on mine isn't functioning correctly...must be some gummy wood residue in the temperature gears.:D
Are you suggesting only coffee drinkers should use Shopsmith equipment:confused:
F. Jim Parks
Lakewood, Colorado:)
terrydowning
Post by terrydowning »
I didn't know there was a coffee maker SPT! That would be useful indeed.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
wiredone
Post by wiredone »
fjimp wrote:Are you suggesting only coffee drinkers should use Shopsmith equipment:confused:
Here in California, we call that humor.
I strongly suggest a daily dose, (along with a cuppa Joe)
www.wirewerkes.com
wiredone
Post by wiredone »
www.wirewerkes.com
