Great design. I must try that one. Jimfiatben wrote:Yeah, for Christmas, for the same daughter, I wanted the same thing. I googled pics and looked at 100s and then designed this:
[ATTACH]16109[/ATTACH]
Taking a simplistic approach, it is 3 pieces of curly maple and designed to take back apart and throw in a drawer when not being used.
plans for a book stand
F. Jim Parks
Lakewood, Colorado:)
stating the obviouse
The trick, obviously, is getting the slots tight but not too tight. Any slop really shows up in how it sits. I shoulda made a drawing. The dimensions aren't too critical, but it has to have enough "shelf" to hold the book without tipping over backwards.fjimp wrote:Great design. I must try that one. Jim
It would be neat to have the dimensions of each piece. I am certain one could figure it out. Then again I already have several of those figure it out projects going:rolleyes: Jimfiatben wrote:The trick, obviously, is getting the slots tight but not too tight. Any slop really shows up in how it sits. I shoulda made a drawing. The dimensions aren't too critical, but it has to have enough "shelf" to hold the book without tipping over backwards.
F. Jim Parks
Will try
Unfortunately, it's now a hundred miles from here. I'll look around the shop the next time I'm out there and see if I kept the template I drew up for it on graph paper.
Don't forget us
Hey jonesuh, whatever you come up with, be sure to post a pic and let us see what you ended up doing.jonesuh wrote:My daughter in law isastudent & ask me if i could mae an adjustable table top book stand ---does anyone have a set of plans?---how best to make one adjustable? as you can tell i'm not very accompolished as a wood worker and plans help me a lot
thanks
heathicus wrote: [url]http://www.woodwrightschool.com/ ... ble-plans/
(Second link on this page. More compact, but a bit complex. I recently watched the episode of The Woodwright's Shop where he built this.)
Watching the Video might help...http://flash.unctv.org/woodwrightss/2800/wws_2804.html
Chucks in Phoenix Mark V(5), Mark VII(2),Power Pro, Planer, Crafter Station, Jointer,Bandsaw(3),Lathe Duplicator,Belt Sander,Jig Saw,DC3300(2),"Sears Router Crafter", Post Drill, Stand alone Overarm Router. Jointmatic ++++,
One blessing to living in Virginia about 12 miles from Monticello (Jefferson's Private Home), was frequent visits to his home. Each time we visited I noticed additional features of his office and desk. Not only did he enjoy using this lazy susan reading/writing device but his arm chair was fitted with candelabras on each arm to assist him with having a lit work area. Remember in his day there were no electric lights. My favorite memory was his bedroom adjacent to his desk area. Jefferson had a bucket of Icy water brought in every morning before he got out of bed he dipped his feet in that icy water. How many of us begin our day that way? Jim
F. Jim Parks
fjimp wrote:It would be neat to have the dimensions of each piece. I am certain one could figure it out. Then again I already have several of those figure it out projects going:rolleyes: Jim
OK, I'm slow but I do eventually get there (sometimes). I found half the template, measured it, edited the picture and made a pic of the template. All just for you Jim!!
[ATTACH]16303[/ATTACH]
[ATTACH]16304[/ATTACH]
I would suggest making a mock-up of cardboard or foamboard (posterboard) to revise the form as suits you and to work out where to locate the slots.
- Cookbook Stand-1.JPG (88.21 KiB) Viewed 5706 times
- Cookbook Stand Template.JPG (198.2 KiB) Viewed 5716 times
Book Stand / Magazine Rack
I have made almost a dozen of these slide together dual functionStands page 56-57. (App to display American Woodworker Issue takes a while to load, but all the dimensions and instructions are there.)
I have made simple versions from pine, Bamboo Flooring, and pine breadboarded glueups. A [ATTACH]16305[/ATTACH] for different widths of material was made to locate the position of the 22 1/2 degree slot. The smaller sizes are very nice, useful.
Advantages are:
1 Two configurations Stand and Rack, just change the way the parts are put together.
2 Ships Flat.
3 Simple.
4 Easily modified for materials or design elements.
Magazine rack configuration on left, book holder configuration on right.
[ATTACH]16306[/ATTACH]
Advantages are:
2 Ships Flat.
3 Simple.
Book Magazine Rack.pdf- (21.87 KiB) Downloaded 498 times
- Book_Magazine Rack.jpg (30.16 KiB) Viewed 5740 times
MK V 520; MK V 510 w/PP DIY Upgrade; MK 5 500; Jointer; Bandsaw; Sliding Table; Conical Sanding Disk; Sharpening Guide, Lathe Duplicator, Jigsaw, Scrollsaw, Beltsander, Ring Master, Biscuit Joiner.
Fiatben,fiatben wrote:OK, I'm slow but I do eventually get there (sometimes). I found half the template, measured it, edited the picture and made a pic of the template. All just for you Jim!!
Thank you sir. That will save me much time and I rather suspect will please several in my family. Your efforts are greatly appreciated. Jim
F. Jim Parks
