The Ultimate Sawsmith Radial Arm Saw Thread
sailseahawk
Belt solution found? The Ultimate Sawsmith Radial Arm Saw Thread
Post by sailseahawk »
Working Belt replacement found: Just installed a link belt (Size 5L) and that does work, change speeds, etc. The saw does now have a new noise at high speed, but that may be an adjustment issue, as I had to disassemble much of the speed change mechanism to size & install. I will continue to fiddle with it and post an update. Also found a 4L150, recommended elsewhere in this thread, does NOT work on my saw. It is simply too loose.
I plan to use use my new-to-me saw as a replacement for my craftsman, since the saw has one more inch of clearance for through-cuts, thanks to blade being mounted on a shaft parallel and below to the motor, and also to run some of my SPTs.
I'll post when I figure this thing out.
delong94
SawSmith blade
Post by delong94 »
I recently ordered and received the 8 inch Woodworker I (Mr Sawdust TCG) blade for my SawSmith radial arm saw from Slivers Mill. It’s on sale now too. It is a great blade. No tear out and cuts were smooth and you need minimal sanding.
sailseahawk
Source for RAS shaft nut sought
Still getting my "new" Sawsmith RAS set up (before I ditch my wonderful Craftsman RAS). Looking for a source for the arbor nut on the right side, ACME RH 5/8 -11. For those not aware, one of the unique features of the RAS is the ability to put the saw blade and guard on either side. This is a significant advantage for miter cuts, compared to other RAS set ups, which have the blade only on the left. I have the nut for the left, but not for the right side. The shaft is 5/8 with a tapered flat, just like a SS, so I could use a SS arbor, but I would like the ability to put my other blade that side. I spent about an hour google searching, but not luck. I'm sure someone makes one. Worst case, a tap is available for $28.
Re: The Ultimate Sawsmith Radial Arm Saw Thread
Source for acme 5/8-11 tap??????? DIE????
jpdalton
Post by jpdalton »
Picked up a few nice NIB accessories for the upcoming Sawsmith restoration! How’d I do??
John Dalton
Massachusetts
1948 10E, S/N 5052 (restored)
edma194
Post by edma194 »
Great parts find. Where on earth do you dig up these things John? It's like you have a time machine or something.
jpdalton
Post by jpdalton »
jpdalton wrote: Sat Dec 30, 2023 9:29 am Picked up a few nice NIB accessories
If anyone is looking for some documentation on these accessories, I’ve uploaded them here:
http://vintagemachinery.org/mfgindex/de ... =339&tab=3
John Dalton
Massachusetts
jpdalton
Post by jpdalton »
edma194 wrote: Sat Dec 30, 2023 11:04 am Great parts find. Where on earth do you dig up these things John?
Clearly spending way too much time on eBay!
John Dalton
Massachusetts
sailseahawk
jpdalton wrote: Sat Dec 30, 2023 9:29 am Picked up a few nice NIB accessories for the upcoming Sawsmith restoration! How’d I do??
Could you please post a pick of the add a tool bracket?
sailseahawk
JPG wrote: Fri Dec 29, 2023 12:51 am Source for acme 5/8-11 tap??????? DIE????
E bay has both.
