What alternatives are there to the Shopsmith 1/4" speed increaser router adapter
wiredone wrote:why not just buy one of these and be done with it?
http://www.shopsmith.com/ownersite/catalog/add_to_cart_d.htm?item1=514632
Do these fit the speed increaser?
wiredone
Post by wiredone »
reible wrote:Do these fit the speed increaser?
I guess some clarification is in order.
What does the business end of the speed increaser look like?
I don't own one so I assumed it took the same type of fitment as the MARK V.
I assumed wrong?
www.wirewerkes.com
Hiding in a Joshua Tree.
damagi
Post by damagi »
wiredone wrote:I guess some clarification is in order.
I assumed wrong?
Nope, won't fit. The speed increaser has a shaft style hole with two set screws on opposing sides. the shaper adapter is a round rod with two flats ground into it as I recall.
damagi AT gmail DOT com
I assumed wrong?
See Post #15 this thread!;)
Ron309753
Post by Ron309753 »
Terry,
If the end of the speed increaser will accept a 5/8" shaft, then get about a 5" piece of 5/8" steel rod. Grind or file a tapered flat on it like what is on the main spindle, and mount a standard ShopSmith router chuck on it. Grind or file two opposite tapered flats on the other end to lock it securely in the speed increaser. If the speed increaser will only accept a 1/2" shaft, have a machine shop turn one end of the rod down to 1/2".
Sincerely.
Ron309753
Ron309753 wrote:Terry,
Sincerely.
Ron309753
'AIUI':D, it is 1/2" to accept 1/2" bits.:rolleyes:
tmoltzan
Post by tmoltzan »
Sorry for the delayed response, but I did find bushings locally that were predrilled and had allen set screws in them. I did have to grind the head of the screws down a little to get the outside smooth. I have mounted these in the speed increaser, but have not had a chance yet to do the project that this was all for.
