Video on bandsaw blade replacement
tomsalwasser
Re: Video on bandsaw blade replacement
Post by tomsalwasser »
db5 wrote:I have this in a Word document (with pictures) and can convert it to PDF if anyone wants a copy.
I would really appreciate a pdf db5, thank you! tomsalwasser at gmail dot com
rjent
Post by rjent »
db5 wrote:
billmayo wrote:I highly recommend reviewing this reference in the Shopsmith Forum posts for adjusting the bandsaw blade tracking starting on 08-05-2011 by JPG40504:
http://www.shopsmith.net/forums/showthr ... djustments
The pictures helps me to understand this procedure when replacing the blade tracking bearings.
Like Tom, I also would like a PDF of that.
rjent dot retired at gmail dot com
Thanks DB5 in advance!
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
"PDF" me!
putttn
Post by putttn »
It would be interesting to hear everyone's discoveries after taking the PDF to their band saw. I'm looking forward to just becoming a lot more familiar with what goes on in there and being able to work on it with confidence. I do have Jacob Anderson's band saw repair video which really helps also.
tomsalwasser
putttn wrote:I do have Jacob Anderson's band saw repair video which really helps also.
I agree the video is excellent. Did you notice the part where he says he does not use any adhesive when he installs new rubber tires? He said the adhesive causes problems and is not needed anyway. My tires are badly cracked and my 2 new rubber tires just arrived from SS.
putttn
Post by putttn »
I heard that and was thinking that it was strange but what do I know!!
billmayo
Post by billmayo »
Shopsmith quit using any adhesive for the black rubber tires sometime in the 1980s or earlier as best I could keep track of. I never used any adhesive on the black rubber tires when I installed them. I used a 3M spray-on adhesive with the orange tires without any negative feedback. I had problems with the orange tires becoming too hot from the saw blade and loosening on the wheel. I recommend the Blue Max bandsaw tires listed on Ebay. I have used many sets of them without any negative feedback from customers.
tomsalwasser
billmayo wrote:I never used any adhesive on the black rubber tires when I installed them. I recommend the Blue Max bandsaw tires listed on Ebay. I have used many sets of them without any negative feedback from customers.
Thanks Bill!
