Good point!Mike907 wrote:The planer parts diagram also shows the blade part number as 513364, so the other number, 505982, is for a set of three.
Planer Blades
Re: Planer Blades
Re: Planer Blades
Besides that is what the ss site says!
Re: Planer Blades
Mike said,
I believe you gave us the correct answer as to the two numbers. It is the difference we see between individual parts and an assembly or in this case a set. My brain must have been asleep yesterday, thanks for the wake up call.
I know when I look at the Molder/Dado Arbor, for example, it is P/N 505506 but the base/threaded shaft part, the set screw, the spacer, the 2 machined washers, the keyed washer and nut each have their own part numbers too.
Mike,The planer parts diagram also shows the blade part number as 513364, so the other number, 505982, is for a set of three.
Re: Planer Blades
JPG wrote:Typically parts numbers are not changed unless the parts themselves change(complete part number system changes excepted).
I thought that for any given part number. It only changed with a supplier change?
Re: Planer Blades
That sounds like something Sears Roebuck does.beeg wrote:JPG wrote:Typically parts numbers are not changed unless the parts themselves change(complete part number system changes excepted).
Re: Planer Blades
When I worked for the Air Force overhauling generators the part number was the number on the drawing. If the drawing was updated it had a dash number (i.e. 201-1 ) and the part number was updated to that. That was the part number you ordered. Part numbers were always the number on the applicable drawing.
