They are things that increase you misery. Say it is a nice sunny day and you are working on something and your trying to remove a bolt. Suddenly the head snaps off, suddenly dark clouds move in and your misery begins. At this point you have two choices, drill the bolt out retap the hole and continue. Or use an easy out and .....
To use a easy out you have to drill a pilot hole, not easy but not real big problem, you then insert the easy out screwing it in backwards which is correct direction to remove the bolt stud again really no big deal. Once the easy out is firmly set in place you then apply pressure and immediately the bolt shaft seems to be turning. Your hopes soar, life is good, the bird are singing! Then the bolt stops moving, you apply a little more pressure, you think it might of moved, so you apply a little more. Things as still good, the birds are still singing. Now you have been sufficiently seduced and you feel safe in appling just a little more pressure. But then it happens! The birds stop singing. The sky darken and life quickly changes as the sickening crack of the easy out snapping off rings through creation.
First your startled, you can't believe what just took place. You look at what you have left in you hands. Sudden the realization of what took place sets into your mind. Your happiness is over, the birds are now dumping on your shoulder! A tear begins to form in your eye. You realized you have been seduced again.
You have been tricked into using an easy out even though the last time you swore you would never use one again. But you heard all the success stories of guys removing bolts that are 1000 years old and were welded in by the hands of time.
However this time was differnt you thought. You were sure you were living you life in such a way the easy out god would shine on you this time. BUT NO! Now you have a broken bolt stud with an easy out firmly imbedded in it. Now not only do you get to do choice one you get to attempt to do it by drilling through a hardened piece of metal that was once an easy out.
At this point I'm usually in tears and what happens next isn't really pretty or important. Let jsut say shortly I will be needing to buy somemore drill bits.
The next thing that happens is my wife hearing my morningful howls of anguish runs to my side. "What happened honey?" she asks. I can't talk all I can do is cry and point. She takes me in her arms and says "It will be okay. We will just get you a new one." I cry worst thinking she is talking about a new easy out but she quickly assures me she is talking about a new whatever it was that had the stupid bolt in that broke off to lure me into using an easy out that set up my misery to begin with.
Easy-outs are misery makers in my book.
