Stuck headstock & carriage
- retiredsoldier919
I spent some time today taking apart my 10ER. I think I now understand why my headstock & carriage are sticking. I also now know what is meant by two wedge locks. After taking off the headstock, I found that there are two wedges, one on each side of the way tube. They pinch the way tube when tightened. I believe that the inside wedge was not loosening when turning the lock handles. There was alot of built-up grease & dirt in the wedge holes. Also I see that my wedge may be worn. What do you think?
[ATTACH]7494[/ATTACH]
- 10ERWedgeLocks1small.jpg (47.39 KiB) Viewed 8164 times
David
10ER - SN:21949, Acquired 11 Jan 2010
That wedge is definitely worn. If the wedges are still round, just file a flat bevel back on the wedges and they should be good. All of the wedges in both of my ER's were out of round, mashed into an oval shape. I tried squeezing them back into round, but I eventually just replaced them.
Heath
Central Louisiana
Central Louisiana
- retiredsoldier919
I got the wax and bought some springs at HD. I also expect to get some brass wedges from a member. Between all that I hope to fix this problem.JPG40504 wrote:su
Johnson's Original paste wax is not a floor wax. Subsequent application dissolves the earlier 'residue'. i.e. It doesn't build up!
Yellow can, red stripe, The Original Formula(make sure those exact words are on the red stripe. UPC code is 46500 00202. Got my last can at Home Depot(Not in the paint Dept.!)
David
- retiredsoldier919
Guest
Re: RE:
[quote="retiredsoldier919"]I got the brass wedges and they work beautifully. Can't believe Shopsmith changed from brass. Thx Rob.[/quote]I know this is an old thread, but where did you get the brass wedges? Used or new? I brought it up for discussion in a new thread, and your post here from 2010 is the only record I can find of someone purchasing brass wedges to replace aluminum ones.
http://www.shopsmith.com/ss_forum/viewtopic.php?t=21122
Sent from my XT1585 using Tapatalk
Re: RE:
I know this is an old thread, but where did you get the brass wedges? Used or new? I brought it up for discussion in a new thread, and your post here from 2010 is the only record I can find of someone purchasing brass wedges to replace aluminum ones.retiredsoldier919 wrote:I got the brass wedges and they work beautifully. Can't believe Shopsmith changed from brass. Thx Rob.
- retiredsoldier919
Re: Stuck headstock & carriage
PM'd you the source. A guy from the forum named Rob.
