PaulRussell's Woodworking Projects
mbcabinetmaker
Post by mbcabinetmaker »
Paul nice job on the plane. Looks to be from around 1939 judging from the adjusting nut. I would highly recommend a low angle block plane. I just couldn't live without one. Also a 5 1/2 is better for a shooting board than a 5. You will hear all kinds of arguments for 7 vs 8 but that all comes down to personal preference whey you get into those large planes. A good rabbet plane and a small to medium shoulder plane are also very handy to have. Good luck in your searches.
Mark
2017 Power Pro Mark 7
paulrussell
Post by paulrussell »
Thanks for the advice, I've now got a set of Stanley #18 & 65 (regular & low angle ) block planes which I will be fettling. The #18 is 1909 vintage with the old-style knuckle lever, while the 65 is a bit newer & in near mint condition. Both require very little work short of a good polishing & sharpening.
I'm sorta pleased to soon be able to work with fine tools from many eras: Stanley Planes (1909-1942), the Shopsmith Mark 5/V (Design 1956/ Build1986), and the PowerPro (2010).
I have a project in mind & could use a bit of help from better minds. When I was a lad my grandparents lived in a tiny rural community. A local woodworker made footstools that consisted of four spindle legs supporting about an 8" diameter, 18" long footrest wrapped in carpet for comfort. The ends were capped with slightly larger finished wood to hide the sides of the carpet.(Sort of an oversized rollingpin supported by four legs)
Unlike every footstool I can find today these were small, comfortable, & attractive. I've long searched for something similar with no results.
I'm pretty sure I'll have no trouble turning the spindle legs or the endcaps. But what I'm trying to figure out is the most cost effective way of making the center, carpet-covered portion. My plan is to joint, plane, & glue up regular construction-grade pine & then turn it. Is this a good plan?
Or should I try to make a hollow box which is then rounded (saving weight), or something completely different like using pvc drain pipe?
Opinions welcome.
Paul
520 PowerPro, Planer, Bandsaw, Jointer, Belt Sander, 20" Scroll Saw, Dust Collector, conical disc
Also: 3D printers, and a homebrew CNC
paulrussell
mbcabinetmake wrote:A good rabbet plane and a small to medium shoulder plane are also very handy to have.
You need to pardon my ignorance: What would be preferred model #s of rabbet & shoulder planes, & how are they best utilized along side power tools? I'm assuming (guessing) that you would cut rabbets slightly shy, and then plane them to a perfect mate. Or??
Paul
paulrussell wrote:...The ends were capped with slightly larger finished wood to hide the sides of the carpet.(Sort of an oversized rollingpin supported by four legs)
I'm pretty sure I'll have no trouble turning the spindle legs or the endcaps. But what I'm trying to figure out is the most cost effective way of making the center, carpet-covered portion. .
If I understand your project correctly - You can glue up 2X4s to make an 8"X8" block about 18" long then turn it.
Another option is to use MDF glued up to an 8"X8" block about 18" long then turn it.
Using whatever you have as scrap - gluing up and turning.
shipwright
Post by shipwright »
If it were me, I'd glue up an octagon using a birdsmouth joint like this: http://www.duckworksmagazine.com/04/s/a ... /index.cfm
They are very easy to make with a tablesaw and all you need for clamping is a bungee cord. They can be made tapered or straight and have a ton of gluing surface. If your saw angle is correct (360 / number of sides) the fits are perfect.
Simply cut the board part way through with the board on the flat, the cut the vee piece out with the same angle but with the board on edge. Leave the other side of the board square. I didn't spend any time looking at the link I gave you but I think it will explain. If not just search "birdsmouth mast" or something like that. The other nice thing , not so much for your project, is that if the column will be seen the grain can be quite uniform all the way around. I used birdsmouth on some walnut columns in our living room. at the price of walnut you don't want to make these solid.
[ATTACH]9365[/ATTACH]
Just tack a bit of plywood over the ends for lathe mounting.
And since I know someone will ask, The dog's name is Wilma.
Paul M
mbcabinetmaker
paulrussell wrote:You need to pardon my ignorance: What would be preferred model #s of rabbet & shoulder planes, & how are they best utilized along side power tools? I'm assuming (guessing) that you would cut rabbets slightly shy, and then plane them to a perfect mate. Or??
Paul a rabbet plane is great for just that, cleaning up and fitting rabbets and planing flush to vertical surfaces. I have a old Stanley 78. I use my small Lie Nielson shoulder plane a lot to fit tenons to mortises, but cheaper versions such as Stanley 92 are common on e-bay. Both work very similarly but a shoulder plane does a better job going against the grain. Be very careful because planes are more additive than any other tool. Even Shopsmiths. I have 4 SS but can't count all my planes even after selling about 25 back in the spring.
I'll try to answer your question as how to use them along side power tools but this will vary greatly from woodworker to woodworker. Planes are meant to leave a finished surface in the hands of a skilled operator both in application and sharpening. Now most of my work is larger items and every thing that goes out of my shop is sanded. You cannot plane one part of a cabinet and sand another part because it will stain and or finish differently. So any planning that I do is eventually sanded as well. So why plane? Well it is quicker and much less dusty than belt sanding. Also I use a block plane to take down face frames flush to the cabinet ends. I have done this with a flush trim bit in a router but you get a lot of blow outs that can be avoided with a sharp plane, and if you ever bobble with the router you have a whole different problem. I use a 5 1/2 to flatten panels before running them through my drum sander. This saves several passes and having to start with 60 or 80 grit paper. I hardly ever change from 120 grit. Another handy trick I have discovered is to use a low angle block plane to cut the cross grain marks out of the rails on my doors after running through the drum sander and before finish sanding. I use a Lie Nielson skew block plane with a fence to remove saw marks from any length board. I use a flea market finger plane about 2" long to break edges on boards. I use my 5 1/2 with a special shooting board that I made to trim small moldings on a 45 degree angle. I even made one to chamfer Festool dominoes. Now that is the ultimate high tech/ low tech partnership. I sold all my jointer planes because I never used them, but I have a 8 inch Grizzly for jointing and there is no comparison in the speed there. If you don't have a power jointer than by all means get a 7 or 8 and learn the skills to joint long stock, and it will take skill and patience. I keep a couple of block planes and a 5 1/4 on my truck for installing along with several sharp hand saws. It is always a joy to me to use a hand plane so that is also a benefit. The key to success is to learn to set up and sharpen. I use a combination of the scary sharp method and waterstones. Although I can freehand sharpen I prefer a jig. http://www.craftsmanstudio.com/html_p/V05M0901.htm It gives me repeatable results and I don't have to think about the angle.
Mark
paulrussell
shipwright wrote:If it were me, I'd glue up an octagon using a birdsmouth joint like this: http://www.duckworksmagazine.com/04/s/a ... /index.cfm
Paul M
Paul -- Perfect! I think that regular 2x4's will yeild just about the perfect size. I can joint one edge, and plane one side to get nice flat surfaces to mate with the V cut as you describe above. Thanks!
Paul
paulrussell
mbcabinetmaker wrote:Paul a rabbet plane is great for just that, cleaning up and fitting rabbets and planing flush to vertical surfaces. I have a old Stanley 78. I use my small Lie Nielson shoulder plane a lot to fit tenons to mortises, but cheaper versions such as Stanley 92 are common on e-bay. Both work very similarly but a shoulder plane does a better job going against the grain. Be very careful because planes are more additive than any other tool. Even Shopsmiths. I have 4 SS but can't count all my planes even after selling about 25 back in the spring.
I've a few cheapie planes from days gone by including a set of tiny infill-style planes from Harbor Freight which aren't too terrible bad considering the cost. Unlike most HF stuff, they were made in India.
The nice ones are the Stanley 4 shown above, and a Stanley #18 with old-style knuckle cap. Ebay-purchased but not yet here are a "Made in England" Stanley #5 (it will be interesting to see how it measures up) and a Stanley #65 low angle block plane. I may end up selling one of the block planes if I settle in on a favorite.
I've been terribly tempted by #7, #78, & #92 auctions, but I need to get the hang of the ones I already own before buying more. At this point I might be better off haunting auctions and estate sales for these more expensive planes.
For now I have a very simple honing guide and the scary sharp system.
Thanks much for all the great advice.
Paul
shipwright
paulrussell wrote:Paul -- Perfect! I think that regular 2x4's will yeild just about the perfect size. I can joint one edge, and plane one side to get nice flat surfaces to mate with the V cut as you describe above. Thanks!
Glad I could help. One thing to keep in mind is that unlike my columns, your drum will be spinning so it is important that when you cap the ends you spend some time making sure you find the true centers for the lathe. I didn't need mine to balance, you do. Of course you can add weights (like wheel balancing) afterwards if necessary but a little care should make that unnecessary.
Paul M
mickyd
Post by mickyd »
shipwright wrote:If it were me, I'd glue up an octagon using a birdsmouth joint like this: http://www.duckworksmagazine.com/04/s/articles/birdsmouth/index.cfm
They are very easy.......
.......Paul M
I'm just going to say......GREAT looking place shipwright!!!
Sunny San Diego
