Bandsaw burns wood
This happened on my Microlux bandsaw. It was burning on some really hard wood. I sprayed the blade liberally and boom! I replaced the blade with a new one and all was good.charlese wrote:Good Idea!!! In my experience, silicone is a good lubricant to use on rubber bandsaw tires and on the adjusting screw shown in Dusty's photo above!
However Since your blade came off the wheels, let me suggest you check the tilt of the upper wheel! A straight edge placed across the upper wheel should leave a 1/8" to 1/4" space in front of the lower wheel.
Hi Puttn! Just dawned on me there might be an easy fix for the burning problem. - - THIS HAS HAPPENED BEFORE TO ONE OF OUR FORUM MEMBERS Take a look at your blade. It may be mounted upside down. That is the teeth may be pointed up rather than down. If this is your situation, it's easy to fix!
Also, it is a wise thing to take the tension off of the blade to leave it on the bandsaw. Constant pressure on the upper wheel arm can cause it to twist slightly. After this happens tracking will be off and in a worse condition, it can cause your blade to come off the wheels.
Let's face it- Silicone is a darned good lubricant the will both, repel sawdust and preserve and re-condition rubber. A woodworker just has to be careful to keep silicone from areas where it will spread or spill onto wood that will be finished.
To eliminate silicone from a wood shop is like eliminating a sharp blade because I once got cut by one.
putttn wrote:Ok. I noticed many of you have the exhaust port. Is there instructions etc to mount one of those?
SS will supply ya with instructions, when ya buy the port.
putttn wrote:For some reason I thought you had to buy the whole cover? Are they still in business and shipping? Last year I ordered the DVD's and never did get them.
Call them and inquire re their status!
FYI:
http://www.shopsmith.com/ownersite/itemfind.htm?item=300000&Submit=Find+Item
putttn
Where does the exhaust port mount? I've got my SS sandwiched in between my workbench and a couple of Festool tables and if it mounts fairly high just under the table I'll have room for it. If not I'm not going to be able to get everything to fit in line. I'm sharing a 3 car garage with 3 cars so everything really has to fit.
Get back online and look again. The email special is there now and the site is accessible.putttn wrote:I received a email offer to purchase the side cover for the bandsaw at a discount from SS but the links to SS don't work. I don't seem to be able to access their website at all. Anyone having the same problem?
Bandsaw Side Cover Upgrade 522221....$42.89 (regularly $61.27)
