Cart for Special Purpose Tools
wingman2010
Re: Cart for Special Purpose Tools
Post by wingman2010 »
I'm trying to make an SPT cart. To hold each SPT, I've stacked 2x4s and drilled 1 1/4" holes. I can't get the hole spacing right so it's too snug for the mounting tubes. Is there a trick to drilling the hole spacing just right? I'm using a portable drill and a 1 1/4 spade bit.
My method is: drill a hole, then use the lathe tail stock as a pattern. Put one leg in the hole i drilled and trace the other leg on the 2x4. Drill the second hole.
I've tried this 3x and I'm getting frustrated. Any help is appreciated. Thanks.
wingman2010 wrote:I'm trying to make an SPT cart. To hold each SPT, I've stacked 2x4s and drilled 1 1/4" holes. I can't get the hole spacing right so it's too snug for the mounting tubes. Is there a trick to drilling the hole spacing just right? I'm using a portable drill and a 1 1/4 spade bit.
Try drilling holes slightly larger than 1 1/4".
1 5/16" oughta work.
BTW the spacing is 7" c-c. Hope you are using a drill press to drill the holes.
benush26
Post by benush26 »
Is it at all possible to use the drill press (or at least horizontal boring) mode?
Because the tubes on the SPTs are parallel, any deviation when using the hand held drill is magnified. One degree makes a big difference! :eek: So if you are off perpendicular to the 2x4 by the smallest amount, the error shows in the next hole (which is probably off a bit, too). Remember you can vary for and aft and side to side compounding the error.
When using the horizontal boring, as long as you set the speed lower for the spade bit and don't force it, it will work fine. Slow and easy is a very good thing at this time.
If there is just he tiniest of binding problems in the holes that you drill, a rasp generally will remove enough material to allow a reasonable fit. There was a time when I would wax the side hoping the SPT would slid out easier until I figured out it cam out fine it was just my reduce upper body strength that was making it more difficult. :rolleyes: :o
The larger the hole, the larger the chance the SPT will set at an awkward angle.
If it makes you feel any better, most who have made stands for the SPTs have found the same frustrations.
Be well,
Ben
joe_cool
Post by joe_cool »
Found this Document Thought it might help.
compactsptcart.pdf
(704.49 KiB) Downloaded 5335 times
delong94
Post by delong94 »
Here is one I found on the net last year from Popular Mechanics too.
SCaster.pdf
(591.71 KiB) Downloaded 4662 times
wingman2010
Y'all are great. Thanks for the tips. I'm glad to know others have experienced this. I can't wait for this weekend. If I finish, pictures will follow.
damagi
Post by damagi »
Compact_SPT_Cart.pdf
(704.49 KiB) Downloaded 4030 times
I happended to have a copy of the file and was looking for it. Here you go to any who would need it
HopefulSSer
Post by HopefulSSer »
I decided to build one of these. Thanks for the plans!
Mark V 510 51-014654
rlkeeney
Post by rlkeeney »
Looks great, I need to make something similar.
Robert Keeney
Tallahassee Florida USA
The drawers will be great to have for storing smaller items. I wish I could have added a couple of drawers to my SPT storage cart.
_
Storage - front.jpg (159.97 KiB) Viewed 57287 times
