PaulRussell's Woodworking Projects
rpd
Re: PaulRussell's Woodworking Projects
Post by rpd »
charlese wrote:That is a really neat solution to repair the table. Very nice work.
Also - My hat's off toward your daughter.
But how in the World did you post those picture two days from now????? Do you often work in the future?
He posted the picture of the pen on March 24, the pictures of the table were posted April 21.
No DeLorean required. ;)
paulrussell
Post by paulrussell »
Thank you to all for the very kind words!
Here is today's playful project from the scraps - cedar door mat, unfortunately a bit small at 18" wide.
Today is Thursday Apr 23 here in KY. Is CA two days behind? :D
I knew y'all are 3 hours behind! ;)
JPG wrote:
charlese wrote:...
It evidently was, back when I posted that!
We're all caught up now!
paulrussell
Today's project -- saw a video and had to try this. A pen with Celtic knot made from embedded coke can. The wood was $2 from Woodcraft and labled "Mystery Wood" which I assume means the label fell off and they don't know what it is. The lighting is a bit deceptive, as both upper and lower sections are the same color.
Did the 'mystery wood' smell like walnut?
paulrussell
JPG wrote:Did the 'mystery wood' smell like walnut?
That was my guess.
paulrussell
Some tap handles for local brewpub
berry
Post by berry »
They look very nice, it would have been great if you'd have provided some info on the process
paulrussell
Oak handles have a thin maple cap on top for better contrast with paint.
Cut blanks 11" x 2" x 1 3/4", drilled end, then painted top surface black.
Carved relief on a CNC using a 90 degree V bit and a 1/8" flushcut bit for flat areas. The maple capped handles were cut deep enough to reveal wormy oak beneath.
Cut tapers on Shopsmith using a homemade jig.
Put dab of two part epoxy in mounting hole, then using a bolt to keep them aligned, hammered a pair of standard hex nuts into base.
Rounded off edges using hand plane. Light sanding. Finished with BLO.
Drank beer.
