Today in the Shop
mbcabinetmaker wrote:http://www.sketchupwoodplans.com/2011/02/27/print-scale-sketchup-part-1/
Try these directions. I make patterns all the time using them. They usually print out on more pages than I feel is necessary but I just align and tape them together.
Thans for the link, Mark.
paulmcohen
Post by paulmcohen »
tdubnik wrote:Paul,
I did a tutorial on how to print to scale in Sketchup a while back. You can find it here. Hope this helps.
Thanks,
I will try it, everything I want to prints fits on one sheet of paper so the extra complexity of piecing together multiple sheets isn't needed.
Paul Cohen
Beaverton, OR
mbcabinetmaker
Post by mbcabinetmaker »
[ATTACH]15774[/ATTACH]
[ATTACH]15775[/ATTACH]
[ATTACH]15776[/ATTACH]
I see a flicker of light at the end of the tunnel.:D
Mark
2017 Power Pro Mark 7
beeg
Post by beeg »
mbcabinetmaker wrote:I see a flicker of light at the end of the tunnel.:D
Lets hope it's knot a TRAIN. :)
mbcabinetmaker
beeg wrote:Lets hope it's knot a TRAIN. :)
Yes it was a train. Went to install on Saturday. The slack A$$ contractor had not done his job and I could only install the upper cabinets. This is going to throw me even farther behind on other projects.
Oh well on the brighter side!!:)
[ATTACH]15828[/ATTACH]
This simple jig (2 pieces of plywood nailed together) that I built last week to hold some pieces while cutting the biscuit slots has already come in handy for a few more projects. It is perfect for holding these skirt boards while I file the edges. A lot better than a helper and it does not talk back.:D
[ATTACH]15829[/ATTACH]
Frames for some laundry room cabinets.
[ATTACH]15830[/ATTACH]
Parts ready to assemble.
[ATTACH]15831[/ATTACH]
Whats wrong with my ruler?:confused:
Mark
mbcabinetmaker wrote:Yes it was a train. Went to install on Saturday. The slack A$$ contractor had not done his job and I could only install the upper cabinets. This is going to throw me even farther behind on other projects.
Nothing. It works well that way and saves one inch of lumber on every piece cut.
Just remember that it starts at one
Nothing as long as everything you measure is over 1" long.
mbcabinetmaker wrote: Whats wrong with my ruler?:confused:
Not a single thing, if you like cloth rulers with the first inch missing. If you use it - don't forget to add an inch to the measurement.
mbcabinetmaker
Actually it is a ruler that I modified to measure my doors. Most of the doors that I build are 1/2" over lay. I cut it off and reattached the brass end and by loosing the first inch I never have to worry about did I or didn't I add for the over lay.
[ATTACH]15834[/ATTACH]
Of course I like to loan it to people just to screw with them.:D
Mark
mbcabinetmaker
[ATTACH]15837[/ATTACH]
One of the projects this week is to build a wooden bar top. I actually built this top last month for a contractor. He called a few days after I delivered it to his office and said that I needed to build another one.:eek: Of course I panicked. When I ask what was wrong he told me that he had made the template wrong.:rolleyes: I felt better after my stomach returned to its normal position. You know not in my throat! I think I will make him pay for that panic attack. :D Of course he made this template as well.
[ATTACH]15838[/ATTACH]
First I glued the template together and then cut it at the miters.
[ATTACH]15839[/ATTACH]
Center top in glue up.
Mark
mbcabinetmaker wrote:[ATTACH]15837[/ATTACH]
I think the 'second' one should cost twice as much as the 'first' one! Seems fair and logical to me!:D
