Speed Control Dial rattle
goana
Post by goana »
On putting back the speed changer and turning on, the speed control dial rattles at lower speeds, between SLOW and Saw/Jointer setting. The rattle goes away beyond Saw/Jointer setting. Seems like the SPRING does not help much in preventing the rattle cause of the grove on 'speed control dial' between SLOW and Saw/Jointer setting.
I do not recall hearing the rattle previously. Am I missing something ? This is the first time I removed the speed changer after I got the used SS couple of months ago.
Thanks
mikelst
Post by mikelst »
There is a small spring that goes behind the dial called the dial spring
number 83 on this diagram
http://www.shopsmith.com/ownersite/partscat/headstockassemblyexpview.htm
that keeps it from rattling.
Page b6 of this pdf shows a better diagram.
http://www.shopsmith.com/ownersite/prod ... 0_1_14.pdf
Mike......... Rowlett, Texas, near Dallas
86 MK V 500/520. 59 MK 5 Greenie Shorty. SS Jointer, SS Planer,
SS Bandsaw, SS Lathe duplicator, SS Belt Sander,SS Molder & Shaper,
SS Tenon master jig, SS Mortising kit, SS 2 1/4' Drum Sanders, Ringmaster, DC3300....
goana
Post by goana »
Thanks Mike. The dial spring, #83, is in place. The speed control dial is the one rattling. I have the spring under it and it is set properly and it does seem to have good amount of tension. Wondering if there is any other thing I need to pay attention to or do differently or change the spring.
Thanks,
nuhobby
Post by nuhobby »
Sometimes the little finger-knob on the speed-control "big red" knob will be loose. It can loosen over time and be a rattler. But if you buy a new one and see it staked very tight, you notice the difference.
Chris
wa2crk
Post by wa2crk »
Check for #73 in Mike's post.
billmayo
Post by billmayo »
nuhobby wrote:Sometimes the little finger-knob on the speed-control "big red" knob will be loose. It can loosen over time and be a rattler. But if you buy a new one and see it staked very tight, you notice the difference.
You can use a center punch to tighten the existing finger knob on the "big red" knob as many finger knobs will become loose and rattle. I allow for a slight movement of the little knob when tighten this knob. A little should do the trick.
