So many of you old heads on the forum boast of how many Shopsmiths you own so with all these extra machines out there.
Has any one ever turned one into a dedicated router table? mount the headstock backwards so in upright position,
the bit would be pointing up. Changing the bit height adjustment would be a snap.
Just a thought it might make a sweeeeeeet machine. Has any one done it yet?
Router configuration
Bruce
Ok Ok, I'm up to four now...
That might be a good idea, maybe. Will the headstock give you the rotational speed you want/need for a dedicated router?lightnin wrote:So many of you old heads on the forum boast of how many Shopsmiths you own so with all these extra machines out there.
Not exactly. I've got a stand alone OPR, so I wouldn't need to do that. However, I also have an original Mark VII. My plans for that machine include it being used primarily(Not exclusively) as a shaper.
Chucks in Phoenix Mark V(5), Mark VII(2),Power Pro, Planer, Crafter Station, Jointer,Bandsaw(3),Lathe Duplicator,Belt Sander,Jig Saw,DC3300(2),"Sears Router Crafter", Post Drill, Stand alone Overarm Router. Jointmatic ++++,
chucks wrote:Not exactly. I've got a stand alone OPR, so I wouldn't need to do that. However, I also have an original Mark VII. My plans for that machine include it being used primarily(Not exclusively) as a shaper.
At what speeds do typical shapers rotate? Do you have OR do you even need a speed increaser?
- Ed in Tampa
I have an extra main table I modified so I can bolt a router to it.
I used the SS as a router for a number of years and the only problem was you have to have a slow feed rate. It was perfect for cherry that likes to burn.
However with soft start, variable speed routers many that can be had for around $100 it does not make sense to do routing on the SS anymore.
But like I said the main table makes a great router table one you can use your fence and miter guage on. Plus it will not sag under the weight of the router.
Ed in Tampa
Stay out of trouble!
dusty wrote:At what speeds do typical shapers rotate? Do you have OR do you even need a speed increaser?
Good question...all that I know is what Nick said
http://www.shopsmithacademy.com/SS_Arch ... Shaper.htm
In other words the 1 1/8 HP motor set-up as a shaper will perform better than a 3 HP router. That's good enough for me. It would be interesting to find out if the speed increaser would enhance it's performance.
