Band saw blade width
buzback
Post by buzback »
I recently bought a Mark 5 with a number of attachments that I have to figure out how to use. One is a band saw that has a 1/8" wide blade installed. I want to install a wider blade, maybe 1/4 inch.
So my question is: Can you just switch blades or are there other little support items that have to be installed with it. I got the operators manual off the Shopsmith website but it doesn't go into detail about switching blades.
beeg
Post by beeg »
Just swap out for the blade ya want. Then adjust the guide blocks and tension the blade correctly.
bosox
Post by bosox »
Yes, you can just switch the blades. Just like what beeg said, adjust the guides and re tension the blades.
