Offset Center for lathe
- stickthrower
I have a stupid question.
Would would you use the offset center for the lathe for making? I watched a video online about it, but I couldn't see what I would use it for. So now I am curious about it.
Thanks,
nathan
Thanks,
nathan
central MN
Tapered turnings , like a tapered leg for a table.
Mike......... Rowlett, Texas, near Dallas
86 MK V 500/520. 59 MK 5 Greenie Shorty. SS Jointer, SS Planer,
SS Bandsaw, SS Lathe duplicator, SS Belt Sander,SS Molder & Shaper,
SS Tenon master jig, SS Mortising kit, SS 2 1/4' Drum Sanders, Ringmaster, DC3300....
Other related techniques
Also, if you plan some offsets into the driven-end of the piece as well, you can turn Ovals. That tip along with many others is in the Shopsmith techniques here:
http://www.woodworkinglathe.com/page10.htm
Chris
- stickthrower
Thanks Mike and Chris.
The SS came with the piece to do offcenter work, and the guy I bought it from said that you could do gunstocks, but I don't know how you would do that.
So I was curious. I am definitely not up to that, but was just curious about it. I watched a video on youtube, but it almost made me more confused than before I knew anything.
Nathan
Nathan
central MN
Any man that can hand turn gun stocks on a lathe is a much better turner than I will ever be.
Abraham Lincoln
Abraham Lincoln
brad_nalor
- terrydowning
If intentionally turning off center AKA Eccentric turning, I also recommend a speed reducer.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
Terry
paulmcohen
stickthrower wrote:I have a stupid question.
Thanks,
nathan
I made an ice-cream scoop handle and a wooden letter opener. The blade of the letter opener is made by offset turning. You end up with a very thin blade with two sharp edges.
Paul Cohen
Beaverton, OR
Beaverton, OR
I've seen a video somewhere turning offset making hammer handles.
first turned centered on both ends then offset both ends then offset the other direction both ends.
Then sanding to taste.
The video may have been on the woodwright's shop
Bruce
Ok Ok, I'm up to four now...
paulmcohen
Steb centers make offset turning very easy and safe and Robert Sorby (who offers them for the Shopsmith) offers several videos and instructions on how to use them.
Paul Cohen
Beaverton, OR
Beaverton, OR
