Magna 620 jointer
Magna 620 jointer
I just purchased this. It has a guard but is not spring loaded. Do you know where I can find a spring or new guard?
- terrydowning
You might try this
Part 55 on this list. A call to customer service should be bale to tell you if this is the same part or not.
http://www.shopsmith.com/service/jointer/jointer_parts_list.htm
Another Option is to upgrade the guard completely.
http://www.shopsmith.com/ownersite/catalog/j_featherguardretro.htm
If you don't have the appropriate taps and drills, you may need this for the retrofit.
http://www.shopsmith.com/ownersite/catalog/j_featherguardinstallkit.htm
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
Terry
judaspre1982
Methinks I would try rotating the knob clockwise(when viewed from the 'top')!;)judaspre1982 wrote:Check here first.
Make sure your guard has the spring tension wound. The knob on the guard should have spring tension if you turn the knob counter clockwise.
If no tension, the spring inside the mechanism may have broke or come loose.
Dave
