Engine won't start
bradman
Engine Needed Cleaning
Post by bradman »
I went out to use my ss for the first time today and the engine makes a whining noise. The engine will not turn. Could I have damaged it by cleaning it up?
SCRATCH THIS< IT NEEDED CLEANING
swampgator
Post by swampgator »
I would remove the belt cover to see if they are in place. It could be insufficient tension on the lower belt, but I'll leave that for the experts here. ;)
Steve, the old Florida gator
I just love it when she says I can go make sawdust. ;) :D
Ed in Tampa
Post by Ed in Tampa »
I hate to nit pick but your Shopsmith doesn't have an engine. It has a motor.
Ed in Tampa
Stay out of trouble!
fjimp
Post by fjimp »
Ed in Tampa wrote:I hate to nit pick but your Shopsmith doesn't have an engine. It has a motor.
Thanks Ed, I desired making that point but don't feel up to potential flack. Jim:rolleyes:
F. Jim Parks
Lakewood, Colorado:)
backhertz
Post by backhertz »
I suppose someone must be able to adapt a Briggs & Stratton engine to a Shopsmith- but it most likely be a 10E/ER. An issue for the 10E/ER forum on Yahoo.
Seriously, it's very hard to tell with what you've shared. This is a question I am unable to suggest anything to you as I am not sure of what you mean by whining. Have you lubricated the motor sheaves? When you say whining, a bearing comes to mind.
But if the motor is not turning, do not try more than a few seconds with the power switch on as you'll fry your motor. Cleaning is a good thing for the motor. Like Swampgator suggests, pull the belt cover off and you'll be able to see what is going on.
Well after you clean & lube it, come on back & provide an update.
skou
Post by skou »
I've heard of 2 stroke engines being fitted to an ER. (Most 2 stroke engines will run in any position, so the Hz mode as well as vertical are possible.) The carburetor might have some limitations, if it has a float bowl.
And think. No extension cords!
steve
peterm
Post by peterm »
see Shopsmith Shavings 6 for one example :D :D :
[ATTACH]20218[/ATTACH]
Peter
garys
Post by garys »
Motor-engine. Depending on who you are, there may not be a difference.
Just try to tell one of the NASCAR racers that their car has an engine, and they will correct you and tell you that it is a motor. :)
garys wrote:Motor-engine. Depending on who you are, there may not be a difference.
A little brain fodder!
http://www.worldwidewords.org/articles/engine.htm
I assume the same can be said about 'over here'(except we call lorries trucks).:D
Then you can ask them why is it in a motor car(riage).:D
Hmmmmm maybe they have it right!;)
