Paul
Motor/capacitor burnt?
- thewriteturn
- Silver Member
Paul
Take the blade and arbor off. Put a drive hub on one of the auxillary spindles. With one hand ready to help the spindle (with the hub), turn on the Shopsmith. Give the shaft a little help and see if the motor comes up to speed.
If it does, use the speed control and turn the speed down to slow and turn the machine off.
If it does run, likely a bad capacitor. Otherwise, you are on your way to a motor shop - which you may want to do anyhow.
Don't leave it under power and just humming or you will be on your way to a motor shop.
