I've been working on a couple of projects that use conduit. The conduit is drilled and connected with bolts so a major portion of the time is in the drilling process.
Of course a lot of sharp bits of metal are also being made. I'd like to control these bits but they have a mind of their own. The best I could do was to vacuum them up promptly but the hose from the vacuum seemed to want to fall every chance it had.
I have a bad back and something that will irritate it is a lot of bending, like having to pick the hose up a lot. I knew I need to solve the problem promptly but I did not want to spend much time on the solution.
Then it came to me.
The solution is for 505/510/520 type machines and makes use of parts you already have.
[ATTACH]21917[/ATTACH]
[ATTACH]21918[/ATTACH]
I keep the vacuum running and pull the hose off to clean up the mess. It worked really well.
So file this away in case you need it sometime.
Today in the shop (vac. hose hold for my project)
- IMG_8524sc.jpg (70.78 KiB) Viewed 1436 times
- IMG_8525sc.jpg (55.87 KiB) Viewed 1436 times
- fredsheldon
I also hang my hearing protectors, dust masks, clamps, etc. the same way
Fred Sheldon
The Woodlands, Tx
The Woodlands, Tx
I like the usage...I guess my only concern would be corrosion in those. Seems like a good choice would be to get some EMT tube for is purpose...cheap, about the right size, and no need to worry about somehow damaging your expensive extension tubes.reible wrote:I've been working on a couple of projects that use conduit. The conduit is drilled and connected with bolts so a major portion of the time is in the drilling process.
Then it came to me.
damagi AT gmail DOT com
