Mark VII from the basement
squashfest81
Post by squashfest81 »
[img][IMG]http://i1315.photobucket.com/albums/t593/squashfest81/e1671fda-7a6a-414c-8ee6-23066eabdcb0_zps101cbafe.jpg[/img][/IMG]
Hello,
New to the forum. I have wanted a Shopsmith since I first learned of their existence online. Found this Mark VII a couple of months ago. Ran smooth, but soon had the dreaded humming motor issue. I really should have followed the sawdust videos. Opened her up to find scary degraded wire insulation. Addressed that, lubed, and couldn't be more pleased.
She was pulled out of Rex Trailers basement, if that rings any bells.
Thanks,
Nice looking M VII! Take good care of the speed control cam!;)(keep the control sheave well lubricated)!
Interesting 'source'.
joshh
Post by joshh »
Welcome! Thanks for the picture :)
- 1986 Mark V 500 Mini
- 1985 Mark V 510 with reversible motor, bandsaw, jointer, and double-tilt.
I offer quality motor reversal, rebuilding, and rewiring. Contact me at HarbourTools@live.com
squashfest81
squashfest81
So where is the scary wiring?
squashfest81
[img][IMG]http://i1315.photobucket.com/albums/t593/squashfest81/IMAG0645_BURST002_zpsea86e3ca.jpg[/img][/IMG]
Hard to see in the pic, but the insulation was extremely brittle and breaking off in pieces. Then shorting against other connectors, causing my motor to "hum" and not spin. It's all clean in there now.
Couple questions. I need a chuck key. Is there a specific key size? Best source?
Searching for the Mark VII emblem that goes on the base in the indentation. Anyone have one stored away?
Thinking of building three drawers to go in the base instead of the dust collection area. Anyone done anything similar?
squashfest81 wrote:[img][IMG]http://i1315.photobucket.com/albums/t593/squashfest81/IMAG0645_BURST002_zpsea86e3ca.jpg[/img][/IMG]
Assuming you have the typical "Jacobs" chuck, a 3326A takes a "K32" key and a Multicraft chuck takes a "KK" key. Ace is de place if you have them, else a different hardware or BB store.
I think I see the shorting spot on the white wire.
I wonder if the shroud at the pulley end is oem?
I have been considering a similar storage idea for when I get to the bottom of my M VII. Although it sucks, the slow speed vacuum is not very effective and I do have a DC3300 anyway. Then there is the where do I get bags 'issue'.
Finally, I have an emblem, but it is cracked. PM me with an address and it is yours if you want.
squashfest81
Thanks for the key info. I'll check Ace.
The insulation issue only got worse as I moved things. Yeah, that white wire, white and red, and a black were all flaking bare.
Storage. I think I'll make drawers. Really basic. I'm thinking just wood runners to cut back on rattles from vibration. The space can't be wasted. I actually pulled the fan off as it will never collect dust on mine. External dust collection, from what I've read, is the way to go. Pic to follow.
Wow. I'll definitely take you up on that. Thanks. I may like this place.
squashfest81
If only someone had a lost supply from 1963?[img][IMG]http://i1315.photobucket.com/albums/t593/squashfest81/IMAG0781_zpsb3b4452e.jpg[/img][/IMG]
I don't, but it had one, buried under sawdust in the base.
