Maybe I am missing something.. I read I thought most of the threads on using the beall polishing system.. Didn't see much about working with the SS
It seems like the adapter slide right on the spindle and locks with one Allen screw.
Nothing else needed pick the right speed and polish.
talking one wheel at a time
Beall polishing n SS
- terrydowning
I built my own triple buff system using some 1/2" all thread appropriate size nuts (6) and washers (12) and some PVC to cover the threads.
Driven either with a drill chuck or my collet chuck with a 1/2" collet. The tail is supported by a 60 degree live center. Very useful for buffing and polishing pens and other small objects.
I can use either on my SS or my Dunlap 9" x 45". Typically the Dunlap though.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
Terry
Correct except it locks with 2 Allen screws. Been using mine for several years with great success. I recommend it.farley wrote:Maybe I am missing something.. I read I thought most of the threads on using the beall polishing system.. Didn't see much about working with the SS
SS MV 520, bandsaw, jointer, planer, belt sander, mortise unit, biscut jointer, speed reducer, tool rest upgrade, sliding cross cut table, DC3300
farley wrote:it works great. the second allen screw doesn't hit the flat but does tighten down.
thanks
Make sure the 'second' screw is not creating a burr.
I think I would remove it!
I would not use a second screw on the round part of the shaft, any burr or dent could become an issue.JPG40504 wrote:Make sure the 'second' screw is not creating a burr.
The other concern I have is that the set screw is coming in at 90 degrees to the tapered portion on the shopsmith shaft. I had issues with this before and others have too (nova adapter for plain 5/8" shaft vs shopsmith shaft).
If the adapter can be re-drilled and tapped to match the taper on the shopsmith shaft that would be ideal.
