What is this?
What is this?
I've seen this on other Shopsmiths, but mine doesn't seem to have it. What is it and used for and is there a part number for it. It's a plastic ring of sorts that sits next to the head stock.
I grabbed the picture from a Craigs list ad which had a relatively clear picture of what I'm talking about.
Thanks.
Thanks.
- WhatIsThis.jpg (11.24 KiB) Viewed 12570 times
What is this?
It is a rubber like ring on mine. It may well be different materials on machines of different age.
It serves the function of spacing between the carriage and the headstock. If you push the carriage as far as you can toward the headstock, you'll find that the limiting factor is that ring.
Now, with a standard saw arbor and blade installed when you lower the table it will come down with the blade near center in the table top cutout.
It's a coarse adjustment of blade position, so to speak. I don't rely on it for critical measurements but I do believe mine hasn't changed much in twenty years.
paulmcohen
I don't remember why but I had to cut mine to get things to fit. It also help the headstock from banging into other parts.
Paul Cohen
Beaverton, OR
Beaverton, OR
Hi,
You can live without the part but it is cheap to replace and all you will need to know is if you have a 500 or the 505/510/520. The length is different between the two. If you have a machine from old days I think they had some sort of screw stop... someone who knows more on this can help you if that is the case.
It is called a carriage stop ring and the part number is 516667 for the 505/510/520 and 504165 for the 500. (You have to find them by looking at the carriage assembly parts lists.)
This came up a couple of months ago. You can probably search it with the right wording and get a lot more info. It is a spacer to allow the carriage to stop against the headstock and allow your saw blade to align with the slot like Dusty said.
Of course if you want to turn something fairly flat, the quill does not extend far enough to reach when you put on the lift assist.
I think that is why I cut mine off but saved it like the pack rat I am. So I still have it in the drawer.
reible wrote:Hi,
I don't remember putting a different one on when I upgraded my 500 to a 510, but that was a long time ago so I could have forgotten. The one I have seems to be the right one, though.
Hi Tim! I cut my original off thinking it was some type of packing. Went without one for years, but then after finding out what it was, I bought one and installed it. This stop ring would have saved my first panel sled from getting sniped away through use.timster68 wrote:I've seen this on other Shopsmiths, but mine doesn't seem to have it. What is it and used for and is there a part number for it. It's a plastic ring of sorts that sits next to the head stock...."
Thanks.
When turning something small, I cut this one off slicing a straight line across the part. Now it is installed again. I just wrapped electrician's tape around the ring (one wrap) and it both works and looks like new, except it is convertible - off or on in a snap (single slice through the tape).
Great info. Thanks. The part is $1.69 so I guess I'll wait until I buy something else.
It would be nice if the S/H was a little more reflective of the size & weight of the item. I know a lot of web companies just charge the S/H based on the ranges of what the item costs.
But I think eBay is potentially the worst - a lot of sellers have overly inflated shipping.
But on the plus side, the cost of stamps is going up again....
james.miller
