Need a finish that will take some heat
drl
Post by drl »
I am in the process of making a 3d tumbling block design trivet out of walnut, hard maple, and lyptus. I would like some type of finish to make the pieces "pop" but don't know what would happen to a finish when a hot pan, bowl or whatever is placed on it. Suggestions for a heat resistant finish.
Regards,
Dwight
holsgo
Post by holsgo »
I believe any film building finish will suffer a bad fate if you place a hot pan on it. Just like laminate countertops. Go with an oil or leave it natural, especially if you plan to wash it in the sink.
dgale
Post by dgale »
I agree - I'd think an oil based finish would be your best bet but not sure that will fullfill your desire for "pop"
'82 Mark V 500 #96309
curiousgeorge
Post by curiousgeorge »
Try some Watco Danish Oil on a test piece. I think that may give you what you want. It's easy to apply. Just wipe or brush on with no brush marks. It soaks in really deep, seals the wood and is easy to maintain, if needed, by simply wiping on another coat. There are several shades as well as a neutral color if you want to keep it natural.
Another really good choice might be wipe on poly for many of the same reasons.
I use both often because they are both pretty much idiot proof. :D
George
Ft. Worth, TX.
Go TCU Froggies
terrydowning
Post by terrydowning »
Plain old mineral oil is another option.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
dgale
Post by dgale »
terrydowning wrote:Plain old mineral oil is another option.
Mineral oil is always my choice for cutting boards or anything else that will have direct food contact.
camerio
Location: Valcartier, just north of Quebec City, CANADA
Post by camerio »
Why mineral oil is also the best ...
It is the only oil that wont go rancid with time.
Camerio
MarkV 520 & Band saw
drl
Post by drl »
Thanks for all the replies. I will agree a film finish would not be the best choice so I think I'll go with mineral oil. Cheap, easy to obtain, touch-ups and refinishing would be easy. I'm still working at getting it together. A lot of pieces, joints and alignments. Thanks all for the input.
Regards,
Dwight
Jack Wilson
Post by Jack Wilson »
Salad bowl finish should work well.
SS Mark 7 PowerPro, 2 SS Bandsaws, SS Belt Sander, SS Jigsaw, 13" Steel City Lunch Box Planer, SS Jointer, Jet 22-44 Drum Sander
derekdarling
Post by derekdarling »
Consider using analyne dye to make the figure 'pop', then mineral oil over that.
Derek Darling
Surrey, B.C. Canada
10ERs, other stuff, you know.
