Premium Casters template
gradyjohn
Post by gradyjohn »
Don't use a pencil to punch the original holes. I stumbled on this by accident. I put the template up on a leg to help line it up a little before I used a pencil. The light from the window showed thru the existing holes. I just lined it up, taped it down and did the same on the other three legs. Tapped and drilled. Wow! the new ones are great.
gradyjohn wrote:Don't use a pencil to punch the original holes. I stumbled on this by accident. I put the template up on a leg to help line it up a little before I used a pencil. The light from the window showed thru the existing holes. I just lined it up, taped it down and did the same on the other three legs. Tapped and drilled. Wow! the new ones are great.
That is so good to hear. A number of us have not done so well (in the past). The older templates left something to be desired.
claimdude
Post by claimdude »
Grady,
I just got the premium caster set (complete with all the hardware) from Shopsmith. The template I got from Shopsmith shows the new holes to be 1 3/4" higher than the old ones. Is it safe to use their template now? There are posts in the forum of the template being off in the past.
Thanks
Jack
claimdude wrote:Grady,
Thanks
Jack
That is 1/4" higher than I put mine but we don't know that we use the same wheels.
Here is a chart I created when I installed my new casters.
http://www.shopsmith.net/forums/attachm ... 1337979388
claimdude
Post by claimdude »
Got my premium casters installed. The Rev d 5-12 version templates were spot on. Grady, the light behind the holes to line of template worked perfectly and quick. Thanks Grady and Dusty!
Jack
[ATTACH]25499[/ATTACH]
[ATTACH]25500[/ATTACH]
2014-06-27 18.23.07_001.jpg (21.91 KiB) Viewed 2578 times
2014-06-27 18.23.16_001.jpg (15.18 KiB) Viewed 2576 times
claimdude, would you please measure for me the distance between the top new hole amd the hole directly below it.
When the wheels are down, what is the distance from the floor to the bottom of the legs?
I'm glad you have them installed and they are working for you. The new casters are great, especially on a rough or dirty floor.
claimdude
Post by claimdude »
Dusty,
The holes are 1 3/4 higher center to center. The wheels look like they just kiss the floor but I haven't looked real close. I will check it later today and let you know.
Jack
claimdude wrote:Dusty,
Jack
That will work great. Thank you for the response. You have your wheels set 1/16" higher than mine which is better because mine do make some discernible contact with the floor..
