Zero Clearance Insert
Why is the cut on a ZCI offset from center?
- rcplaneguy
The ones I made for my table saw are off center to allow access for blade changing wrenches. And to have space for a finger hole for grasping.
http://youtu.be/Jgh1Hqg1LY8
Be sure to look at the following video at the 1:55 mark. ;-)
http://youtu.be/U66tr4r0Pyc
John
I don't know why and for that reason when I make ZCI I do not offset the cutout but for the thickness of the blade.
I am speaking of a 510/520 configuration now. When the carriage is slid up against the rubber bumper on one side and the headstock on the other side, if the quill is unlocked (no quill extension), the left side of the blade will be right on the center line of the table insert.
A related thread.
A related thread.
Because God made it that way!db5 wrote:Why is the cut on a ZCI offset from center?
If it were closer, Some folks would try to get it centered to within 0.005!:D
Really! The centering relies upon a rubber sleeve bumper!
Actually, it is because that is where the user put it, if it is in fact offset.
I just looked at the catalog and discovered that Shopsmith does not offer a ZCI. They do sell a blank table insert so that you can put the cutout wherever you want it.
I put mine where I do because I use that as an aid to verifying table alignment.
As a side comment, ZCIs don't remain ZCI very long unless you are very careful. This is particularly true of the Shopsmith because of the unpredictable relationship between the headstock, the carriage and the quill.
I don't discard my ZCI just because the cutout has gotten wider. I just don't rely on them as zero clearance. As the cutout gets wider, a ZCI simply becomes a table insert.
[quote="dusty"]...As a side comment, ZCIs don't remain ZCI very long unless you are very careful. This is particularly true of the Shopsmith because of the unpredictable relationship between the headstock, the carriage and the quill.
I don't discard my ZCI just because the cutout has gotten wider. I just .../QUOTE]
raise the blade 1/4". Bingo- new ZCI.
My ZCI cutouts tend to get wider not longer. Raising the blade...hmmmkeakap wrote:dusty wrote:...As a side comment, ZCIs don't remain ZCI very long unless you are very careful. This is particularly true of the Shopsmith because of the unpredictable relationship between the headstock, the carriage and the quill.
Hmmmmm! A reason to not lower more than necessary the first time.dusty wrote:keakap wrote:
Confusion
I've only made a couple, but each time, after I lower the table as far as I can, to make as long a slot as possible, I remove the ZCI and extend the cut towards the rear so that the upper guard has a place to slide down before using it. Saber saw works well.
Do most of you not use the upper saw guard (or riving knife) when using a ZCI? I understand I may be over zealous about safety, but wouldn't omitting the guard negate some of the benefit of the ZCI?
Be well,
Ben
Be well,
Ben
