lathe chisel rack
tomsalwasser
lathe chisel rack
Post by tomsalwasser »
Greetings fellow sawdust makers.
I decided to take the lathe chisels that I own but have never used and put them out where I will see them every day, in the hope that I will start turning. I acquired these chisels over the years in the "boxes of stuff" that accompanied 2 used Shopsmith purchases and a Craftsman table saw. I used a 10 foot piece of pvc and a few wood scraps for these racks. I think the pvc really made a mess of my saw blade.
rjent
Post by rjent »
What an outstanding idea! Looks good .... :)
Dick
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
rpd
Post by rpd »
Very nice.
I was thinking just yesterday that I needed to make a rack for my lathe chisels, and this design looks like a quick and easy solution.
Turning is lots of fun. Try it, I think you will like it.
ps Where I live the black pipe is made of ABS, the PVC is white.
tomsalwasser
Thanks Dick and Ron. I copied a design that Mr. Google showed me. I like your first pen Ron, I hope to make one soon. How do you sharpen your chisels?
I did not realize that I bought abs pipe, not pvc. I wonder if there's much difference when used as intended for plumbing?
tomsalwasser wrote:Thanks Dick and Ron. I copied a design that Mr. Google showed me. I like your first pen Ron, I hope to make one soon. How do you sharpen your chisels?
There is! pvc = cold/waste cpvc = hot abs=waste
tomsalwasser wrote: I did not realize that I bought abs pipe, not pvc. I wonder if there's much difference when used as intended for plumbing?
Check your local area building codes!!!
There are locations where ABS can be used only for DWV (drain/waste/vent).
http://www.ppfahome.org/abs/absgeneral.aspx
Be aware that there are version of PVC that is not potable.
rpd
Post by rpd »
You've got to love Mr. Google.:)
Did see the pens and wands I did this past weekend?
For sharpening I use a 1" sander/grinder that I bought at Lee Valley,
[ATTACH]25910[/ATTACH]
but just use what ever sharpening equipment you have, a bench grinder, belt sander, strip sander or disk sander should all work if set up properly.
So far I have mostly used the skew, at first it was hard work and hard to control but after I got it sharpened and honed properly it cuts easily with a light touch.
To sharpen and hone the skew I do it like Cap'n Eddie
sharpskew, Skew Sharpening tactics and close-up on skews
He also has several videos on pen turning.
Another site I found recently is the Tiny Trailer Workshop, this is one of his videos. #37 How I turn an Ebony penhttp://www.shopsmith.net/forums/www.youtube.com/watch?v=6feLTjF35z4&list=UUlek5Vj9XQWnQQQB73uAaRQ
