What are the bolts for? Mark V
I have some bolts threaded into the bottom of my table saw table. They are not holding anything. Any clue what they might be for? I'd show pics but I am having trouble uploading for some reason.
Without a pic it's hard to say. Is your pic less than 1.43mb?
Those bolts may be the table leveling bolts for when your in drill press mode?
The other magic "size" number is 1024x768 which is the max. that you can post here.ibskot wrote:I have some bolts threaded into the bottom of my table saw table. They are not holding anything. Any clue what they might be for? I'd show pics but I am having trouble uploading for some reason.
Here are a couple of pictures showing some bolts for you to look at. If these are the ones then they are for adjustment in drill press mode so the table is stopped at 90 degrees, (there are also stops at 45 degrees) this is just for your information.
[ATTACH]26146[/ATTACH]
[ATTACH]26147[/ATTACH]
- IMG_4773msc.jpg (115.03 KiB) Viewed 5151 times
- IMG_4772msc.jpg (100.15 KiB) Viewed 5151 times
Admin increased that to 1024 x 1024. i.e. 1024 either/both hor/vert.reible wrote:The other magic "size" number is 1024x768 which is the max. that you can post here.
