18 inches of waytubes
I chopped 18 inches off my waytubes, Curious what people done with the leftovers, I was considering cutting short pieces and making drawer pulls for large cabinets. Thought I would ask and see what other ideas were out there, Do not particularly want to use them for table legs although they are a good height, Thanks.
- 2centsworth
Scrap...
I like you wasn't sure what to do with them. The better half said take them to the scrap yard and get them out of the garage. $6 bucks later I am glad I freed up the mess.
Jerry Penny
2centsworth
The Woodlands, Tx
SS 520 SN#518424 2000 (reversed motor), Shopsmith 10 E (shorty) fully restored by Skip with DC motor, Shopsmith 10 ER fully restored by Skip with DC motor, Shopsmith 10 ER (under going restoration), Greenie Shorty sanding station, Greenie Mini jointer station, SS Bandsaw power station, SS Planner, SS overhead pin router, SS Belt Sander, SS Strip Sander,, SS Jigsaw, SS Dust Collector, Ringmaster, and still having fun looking for more !
2centsworth
The Woodlands, Tx
They make wedge position holders when removing/installing the headstock on the way tubes. Work far better than paper towel core tubes.
A pair in a hinge end casting(securely mounted) makes a handy headstock 'holder' while 'servicing'.
Me, I never discard anything. Yes it shows!;)
- "Wild Bad Bob"
I am back!!!!!!!!!!!!!!!!! Nephews is grate but no at home net!!!!!!!Wind chimes!!!!!!!
I used the cutoffs to make a jig for fixing headstocks. I had an extra pivoting end, so I mounted that to a piece of plywood.
damagi AT gmail DOT com
Re: 18 inches of waytubes
sharka wrote:I chopped 18 inches off my waytubes, Curious what people done with the leftovers, I was considering cutting short pieces and making drawer pulls for large cabinets. Thought I would ask and see what other ideas were out there, Do not particularly want to use them for table legs although they are a good height, Thanks.
I made a shorty from parts I bought on eBay. I cut 18" off the tubes and kept them. "Don't ever throw anything out!!!" Years later when I bought the Power Pro and double tilt upgrade I used the old head stock and the bench end castings along with more parts from eBay and the 18" cutoffs to make a dedicated MK V drill press. The full length way tube are 10er thick tubes.
- DSCF1154 (480x640).jpg (219.29 KiB) Viewed 3810 times
- DSCF1168_Small.jpg (294.03 KiB) Viewed 3810 times
Very nice 'conversion'. I think I woulda put the '10' tubes on the 'power pro' machine.jsburger wrote:sharka wrote:I chopped 18 inches off my waytubes, Curious what people done with the leftovers, I was considering cutting short pieces and making drawer pulls for large cabinets. Thought I would ask and see what other ideas were out there, Do not particularly want to use them for table legs although they are a good height, Thanks.
I intend to have an early 510 with pp upgrade in an A casting and 10 tubes.
Think multi generational.
I used some cutoffs to help build a wood "cradle" in a combination shorty+OPR station. See the 2nd photo in the thread here:
http://www.shopsmith.com/ss_forum/viewt ... f=7&t=6384
Have fun!
Chris
Have fun!
Chris
JPG wrote:Very nice 'conversion'. I think I woulda put the '10' tubes on the 'power pro' machine.jsburger wrote:sharka wrote:I chopped 18 inches off my waytubes, Curious what people done with the leftovers, I was considering cutting short pieces and making drawer pulls for large cabinets. Thought I would ask and see what other ideas were out there, Do not particularly want to use them for table legs although they are a good height, Thanks.
I made a shorty from parts I bought on eBay. I cut 18" off the tubes and kept them. "Don't ever throw anything out!!!" Years later when I bought the Power Pro and double tilt upgrade I used the old head stock and the bench end castings along with more parts from eBay and the 18" cutoffs to make a dedicated MK V drill press. The full length way tube are 10er thick tubes.![]()
Think multi generational.Parts from the 'beginning' and the immediate present and times in between.
The machine I converted to the Power Pro was my original MK V 510 I bought new at Woodcraft in 1994. It is now a 520 Power Pro MK 7 and already had 10ER way tubes.
When I built the shorty years ago I had the 10ER tubes but I just couldn't bring my self to cut them for the shorty. So I put them on the then 520 and used the 520 tubes on the shorty along with a set of bench tubes from eBay.
