Lathe Setup
brown50
Lathe Setup
Post by brown50 »
I have been working with a 12" throw midi lathe, and a larger lathe at the Army craft shop. Turning pens, natural edge bowls, bottle stoppers, pepper mills, etc.
I now have a SS Mark 7 and am having trouble with set ups for short spindle work, like 6" pepper mills, and other short spindle work.
Is there a site or reference which shows set up configurations?
Welcome to the forum! Your Shopsmith will give you lots of pleasure!
Got to remember the spindle. Extending the spindle will help a whole lot. I made some 6" salt and pepper mills and don't remember major issues.
brown50 wrote:I have been working with a 12" throw midi lathe, and a larger lathe at the Army craft shop. Turning pens, natural edge bowls, bottle stoppers, pepper mills, etc.
Do you have a 'short' tool rest? 4" IIRC.
Can you extend the quill to increase space?;)
brown50
Post by brown50 »
I do have the 4" tool rest, but in order to use the tail stock for support, I can't arrange the tool rest to get close to the workpiece.
brown50 wrote:I do have the 4" tool rest, but in order to use the tail stock for support, I can't arrange the tool rest to get close to the workpiece.
Which tailstock center are you using?
algale
Post by algale »
This seems kind of obvious, but have you moved the headtock over sufficiently to the right? With the headstock and carriage moved to the right, you should be able to extend the quill (with the lathe drive center attached) and touch or come darn close to touching the dead center. Don't forget to re-lock the headstock. Now, if you have the universal tool rest as opposed to the standard tool rest, it won't reach quite so far over....
Oh, and welcome!
Al
brown50
Post by brown50 »
For pens I am using a spindle saver, I have a couple of live centers I use mostly.
I also got the Universal Tool Rest which helps, except it takes up a lot of space between the head stock and tail stock.
brown50
Post by brown50 »
That's a thought. Hadn't come up with extending the tailstock
algale
Post by algale »
brown50 wrote:For pens I am using a spindle saver, I have a couple of live centers I use mostly.
The Universal Tool Rest definitely limits how short a piece you can turn between the standard drive center and dead (or live) center. You can get an extender for the live center.
