how do I post photos to this forum?
Vector
Post by Vector »
This forum does not have instructions on how to post photos or videos.
I need help.
everettdavis
Re: how do I post photos to this forum?
Post by everettdavis »
While you are writing (or later editing) your post you then move down to
Upload an Attachment which takes you to Browsing for it, then uploading it,then positioning your cursor at the place in your text where you want it, then select place inline.
Watch that you first select the right image after uploading if you have more than one, else you may place the same image in multiples.
Watch the size of the files you try to attach. I am not sure what the limits are, but there are limits.
Everett
I believe that the picture size limit is 1000 pixels, for both width and height.
BuckeyeDennis wrote:I believe that the picture size limit is 1000 pixels, for both width and height.
The max file size is 2MB. If the picture is larger than that it must be resized. I usually resize my pictures to 640X480 and they are around 200KB. Even 1024X768 is under 300KB. I always use max resolution on my camera which is 4000X3000 and the resulting file is over 4MB so I always have to resize to upload.
Vector wrote:This forum does not have instructions on how to post photos or videos.
I need help.
Ah but it does. Initiate a post and then look just below the message box. Click on "Attachments" and then either load photo files from your computer or drag and drop them there. Can't get much simpler. Yes, size becomes important but if your image is too large you will be so informed and you will then have to resize it/them.
Assembling Mark V 510 Tables and Rails 002.jpg (1.23 MiB) Viewed 4724 times
Vector, I do hope that you are now able to post pictures. If not, let me know.
