Business card holder
ExtraMile
Post by ExtraMile »
White oak and Aluminum.
Stainless steel screws.
3-1/2 inches square, 1-1/4 inches tall.
I will make multiples of these. I will peddle them at flea markets!
I am a true blue Xylophiliac, who also is a Nemophiliac ;)
Gene Howe
Re: Business card holder
Post by Gene Howe »
Kinda industrial...steampunkish. I like it.
Good luck with them.
ExtraMile
Post by ExtraMile »
So, what or which blade can I use to cut aluminum on my bandsaw? Please advise!
joedw00
Post by joedw00 »
Really like the White oak and Aluminum look.
Joe
Being a VETERAN is an honor
Being a GRANDPA is priceless
Gene Howe
Post by Gene Howe »
For the smoothest cuts I would suggest for 1/4" aluminum, a 10 to 14 TPI blade with constant pitch. You could probably use a wood working blade but they generally have a variable pitch. would require a bit more work to smooth it out.
nuhobby
Post by nuhobby »
That is a sharp invention!!! Great look.
Chris
ExtraMile wrote:So, what or which blade can I use to cut aluminum on my bandsaw? Please advise!
If you want a definitive answer, call Suffolk Machinery the maker of Timberwolf blades. They even know what a SS is and gave me good advice when I called and wanted a selection of blades for various things including a non-ferrous blade for soft metals.
BTW, if you order direct from Suffolk the blades are much cheaper than the resellers.
benush26
Post by benush26 »
Mike Young used a Lennox blade to cut metal (steel actually but they have blades for most needs). They make blades in 72". Available through many sources including Amazon.
Be well,
Ben
ExtraMile
Post by ExtraMile »
Bizz Card Holder, Round two: Black Walnut and Aluminum
And a scrap of Black Walnut, with a big ole knot in it, to give it true character... for a tea light, holder!
ExtraMile
Post by ExtraMile »
Walnut, Poplar & Malaysian hardwood dowels.
I finally was able to succeed in a doweling project! Even though these are small, IMHO, they look awesome!
