Been some interest in magnificent 2 x 4 projects lately. Here is a teeny one.
It's purpose will be revealed later.
Feel free to post a guess.
2x4 Mystery back.jpg (641.07 KiB) Viewed 8645 times
2x4 Mystery front.jpg (731.82 KiB) Viewed 8645 times
2x4 Mystery clue 1.jpg (435.01 KiB) Viewed 8645 times
2x4 Mystery clue 2.jpg (747.68 KiB) Viewed 8645 times
Home designed and built CNC router, another CNC router desktop size, Avid 5x10 Pro CNC w/ATC, CNCed G0704 milling machine
Laser engraver
Way too much other stuff and not enough space
Dick 1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
Laser engraver
algale wrote:Cover plate for an access hole on the headstock? Curious what the material is that was used for the logo.
I'll bet you nailed it! Maybe on a Mark VII?
1951 jigsaw X 2
MVII headstock is close(after all the logo is specific to a Mark VII).
The photo is of the headstock access hole cover.
One who has been paying attention to certain recent posts by me will know!!!
I have not taken a pix of the 'reveal' yet.
It definately will go on the Mark VII. Headstock? No.
A 'unique' feature of the Mark VII was the motor driven vac. A forerunner of the DC 3300. The bag however was paper and installed in the box like base. The vac hose was connected through a hole in the rear cover.
2x4 Mystery reveal back.jpg (643.44 KiB) Viewed 8431 times
From the exterior.
2x4 Mystery reveal front.jpg (888.44 KiB) Viewed 8431 times
Back piece mounted from the inside.
2x4 Mystery reveal rear.jpg (871.48 KiB) Viewed 8431 times
Finally the real purpose.
2x4 Mystery reveal face.jpg (535.6 KiB) Viewed 8431 times
It is merely a hole plug.
I am not satisfied with the photo print. Color is not right. That blueness should be light gray.
I almost destroyed it by deciding to deepen the inside tapered ring. The painted part ended rolling across the floor(I cut all the way through). It is glued back on. Hopefully it will hold. The logo print and plastic cover is held on by the inside of the ring being tapered(larger than the outer diameter).
