Being a new with the Shopsmith how do I take the dead center off and replace it w the love center I have? Looked all over this place and YouTube but no luck. Once the live center is in how do I make sure it matches up with the other end?
Thanks
Brian Miller
Dead center off?
Re: Dead center off?
Tap the outside end of the dead center with a mallet or use a block of wood and a hammer.Jeepmiller09 wrote:Being a new with the Shopsmith how do I take the dead center off and replace it w the love center I have? Looked all over this place and YouTube but no luck. Once the live center is in how do I make sure it matches up with the other end?
Thanks
Brian Miller
To check alignment, slide the headstock over to the right and see if the point on the drive center matches up with the point on the dead/live center.
Jeepmiller09
Thank you for the advice! I had to full remove that entire piece the 2 nuts the sleeve and the dead end and let spray WD40 on it to free it from the grip of the rust! It gave a good fight but I won in the end. The new live center matches up perfectly with the headstock! To bad i am tearing it all down right now to really polish up the pipes! Can't wait to finish turning my cup i started!rpd wrote:Tap the outside end of the dead center with a mallet or use a block of wood and a hammer.Jeepmiller09 wrote:Being a new with the Shopsmith how do I take the dead center off and replace it w the love center I have? Looked all over this place and YouTube but no luck. Once the live center is in how do I make sure it matches up with the other end?
Thanks
Brian Miller
- everettdavis
How is the tear down and re-assembly coming? You said it all started as you set out to make a cup.
Did you take pictures along the way? Please post some when you can.
Everett
Everett
