Hidden Hinges for Cribbage Board Idea
gatheringsplinters
Post by gatheringsplinters »
Greetings!
So, I'm looking at making a cribbage board that folds over on itself. I'd prefer to have the two sides of the board flush and the hinges hidden when it is open.
Any advice on what type of hinges might allow for something like this?
Thanks in advance!
Mark V 500 (1984) - Shopsmith Bandsaw (Older Model with Cast Iron Table) - Shopsmith Jointer
Woodworker Level: Beginner
Boulder Colorado
Instagram: gathering_splinters
Youtube: gathering splinters
Re: Hidden Hinges for Cribbage Board Idea
gatheringsplinters
Not sure, I've never used that type of hinge so I'll have to look into it.
Thanks!
Boulder Colorado
After noticing those barrel hinges are for 1/2" wood. You may be better served by shopping the Soss invisible hinge in the internet. You might be able to find some locally. They are not all barrel hinges.
There re different types of Soss hinges. Some small and some for lrge heavy doors.
This site has a video to show different types of Soss hinges. http://www.soss.com/invisible-hinge.html
If you are using 3/4" wood, maybe the Soss 203 or 303 might work for you.
Ed in Tampa
Post by Ed in Tampa »
Problem with the barrel and SOSs hinges is they are visible when open and hidden when closed. OP was looking for hinges that are invisible when open.
rpd
Post by rpd »
Ed in Tampa wrote:Problem with the barrel and SOSs hinges is they are visible when open and hidden when closed. OP was looking for hinges that are invisible when open.
The cribbage board is not a typical application. :)
If the barrels are drilled in the end grain then when the board is open (flat on the table) the hinges would be closed (not visible),
when the board is folded (closed) the hinges would be visible.
A couple of 100 ought to do. Notice the 1/2" depth which precludes surface peg holes. But the barrel type may be preferable.
Then there are plain old butt hinges, but they need pin exposure on the bottom.
