I picked up this belt sander at a local flea market. Could not pass the chance to see if I can restore it, and connect it to my SS 510.
$5 Belt Sander
- retiredsoldier919
$5 Belt Sander
Last edited by retiredsoldier919 on Wed Mar 01, 2017 12:16 pm, edited 1 time in total.
Re: $5 Belt Sander
I'll take it off your hands for $5 or even $50. I could use a reasonably priced one.
Re: $5 Belt Sander
WOW! Cast iron!! Bushing bearings?
- retiredsoldier919
Re: $5 Belt Sander
I think it has bushings. Both rollers move smoothly, with no play in any direction. I think it may have never been used. I think the fact that the face is painted the same color as the body and shows no wear at all. I thought the face would be polished bare metal. In any case, this will my first attempt to use electrolysis.JPG wrote:WOW! Cast iron!! Bushing bearings?
Re: $5 Belt Sander
That will take the paint off.retiredsoldier919 wrote:I think it has bushings. Both rollers move smoothly, with no play in any direction. I think it may have never been used. I think the fact that the face is painted the same color as the body and shows no wear at all. I thought the face would be polished bare metal. In any case, this will my first attempt to use electrolysis.JPG wrote:WOW! Cast iron!! Bushing bearings?
Do take the aluminum stuff off first.
- retiredsoldier919
Re: $5 Belt Sander
Oh yes. I do plan on disassembling it and repainting afterwards.JPG wrote:That will take the paint off.retiredsoldier919 wrote:I think it has bushings. Both rollers move smoothly, with no play in any direction. I think it may have never been used. I think the fact that the face is painted the same color as the body and shows no wear at all. I thought the face would be polished bare metal. In any case, this will my first attempt to use electrolysis.JPG wrote:WOW! Cast iron!! Bushing bearings?
- retiredsoldier919
Re: $5 Belt Sander
garys wrote:I'll take it off your hands for $5 or even $50. I could use a reasonably priced one.
Sent you a PM about this. I may not get to this anytime soon, so I'm willing to part with it.
